I was using an adafruit fona board with an arduino mega board (5v) for several years until they discontinued the FONA boards. I found a new 4G LTE board 3.3v and used it with the Adafruit ESP32-S3 TFT Feather. I am using an output pin to control a solid state relay to toggle the conditioner on my boat (120 VAC) The SSR says 3-32v DC input but when I tried it on the boat the SSR would not activate. I measured the pin voltage on the ESP32 and it was only 2.2v. As a workaround I used this Adafruit QT 3V to 5V Level Booster Breakout Product ID: 5649 which boosted the pin voltage to 4.4v, enough to trigger the SSR.
My question is why is the ESP32 pin voltage so low ? I thought it was a 3.3v device but searching around I found articles that say it can vary from 2.2 to 3.3v. Do different pins provide higher voltages ?
Here is how I defined the pin on the esp32
#define AirCondRelayPin 15 // solid state relay, black GND, orange to pin 15
pinMode(AirCondRelayPin, OUTPUT); // this is a solid state relay
digitalWrite(AirCondRelayPin, LOW); // turn off airCond solid state relay 120v
digitalWrite(AirCondRelayPin, HIGH);
thanks
ESP32-S3 TFT Feather output pin only 2.2v
- Franklin97355
Re: ESP32-S3 TFT Feather output pin only 2.2v
Have you tested the pin unconnected or tested the current drawn? It might be the SSR is drawing too much for the pin to supply.
- jimk123
I think it was disconnected from the ssr when I was troubleshooting, unfortunately, the boat is over an hour away, making testing more challenging, buying a second board so I can confirm here at home, thanks
- Franklin97355
I'll see if anyone knows if there is a fix.
- adafruit2
are you using an oscilloscope? probably the SSR current was high and it was drooping the voltage, the current output from a pin is only 3mA or so
- jimk123
sorry I don't have an oscilloscope. I did buy duplicate hardware to repro at home but noticed when I measured the + and - on the SSR when i set the pin high it read 3.3v. next step I was going to swap my new esp32-s3 with the one the boat and see if it is different.
In the meantime the Adafruit QT 3V to 5V Level Booster Breakout seems to be working.
thanks
thanks
- adafruit2
did the swap fix it?
- jimk123
I did build a duplicate setup at home since the original esp32-s3 tft board is on a boat over an hour away and it work fine, I measured the voltage on the SSD from the ESP32 and watched it go from 0 to 3.3v when I had the code turn it on.
I assume it is the specific board on the boat and I will need to swap it out.
thanks
thanks
- adafruit2
whats the impedance of the SSR - it could be it works now but the pin will be damaged from driving a low impedance load. its not uncommon to have a driver/buffer for an SSR!
- jimk123
Apologies, not an engineer and not sure what you mean by impedance and needing a driver ? Does Adafruit sell a breakout board for this ?
This same setup worked for years on mega board but that was 5v based
- adafruit2
the SSR may require more power than the pin can provide. you can look at the SSR datasheet, ESP32 pins can provide maybe 5mA but atmega can do 10-20mA
- jimk123
thank you
is there a board that adafruit sells to do this ?
- jimk123
I found this on the desc of the SSR:
Trigger Current: 7.5mA/12V
Control Voltage: 24-380V AC
Input Voltage: 3-32V DC
Zero Cross
Zero Cross
- jimk123
would something like this work to drive the SSR ?
Adafruit MOSFET Driver - For Motors, Solenoids, LEDs, etc - STEMMA JST PH 2mm Product ID: 5648
- adafruit2
thats a 'drive low' mosfet, you probably need to drive it high to turn on the SSR right?
