I've been using trinket M0s as debugging system for many complex boards I design, at least 20 so far. Using arduino for code and programming. The M0 always boots up in "run" mode (magenta LED), pressing the button once restarts the code, magenta LED. I have to press button twice to get into bootloader mode (green LED) to program. But today I loaded some new code and it never went to run mode, arduino gave all the usual messages. Pressing the button once flashes magenta for a few mili-seconds then right back to green.
I tried a different cable, exactly the same thing. It now powers up in green mode. I tried a trinket M0 not mounted on a board that had previously been loaded with code, exactly the same thing. again tried different cables. I tried a different computer that had never had a trinket M0 connected. I first downloaded the latest Adafdruit windows USB drivers. ( all the computers are running Win10 22H2). Again exactly the same thing, starts up in bootloader mode. I tried a brand new Trinket M0, straight out of packaging, again starts up in bootloader mode, button never pushed.
I've tried updating the driver, uninstalling and anything else I can think of.
I just tried another board with a trinket M0 already soldered on, that I had used for debugging a couple years ago, and it works perfectly!! All computers, all cables. Well to keep going I can unsolder that trinket M0 and solder it into the current board, but that is a pain in the neck.
So why do three trinket M0s all of the sudden stop working (including a brand new one) and one I had already used still mounted on its board, still work? This doesn't make any sense. The only time I've ever had anything like this was old GPS chips that had a week rollover all at the same time. I have a feeling that is might be USB driver issue, but then why does that one board work?
Any hints would be greatly appreciated, the trinket M0 is a pivotal part of bringing up new boards. I'm stuck right now.
Thanks,
John S.
Trinket M0 always boots up in bootloader
- johnswenson1
- mikeysklar
Re: Trinket M0 always boots up in bootloader
John,
This is a interesting problem.
Two things to try:
1) Check the bootloaders on the different Trinket M0's? Are they all the same version? Is the older bootloader working better for you? Here is a link to the different releases for the SAMD21 and notes.
bootloader version - look at this file. v3.15 is current.
2) On the newer boards that are going straight to bootloader instead of running the Arduino code do they show that same behavior with a basic blink program loaded or do they behave correctly?
Two things to try:
TRINKETBOOT/INFO_UF2.TXT
- johnswenson1
Problem solved: my arduino environment had some how been changed to a different board that used a SAMD21E processor with different memory sizes. Changing it back to Trinket M0 now works fine. I can't believe I didn't notice that.
Thanks for looking at this.
(red faced)
John S.
(red faced)
John S.
- mikeysklar
Thank you for the followup. I had assumed nothing had changed within the IDE settings.
