I'm totaly new on IOT stuff, i try to follow this tutorial :https://learn.adafruit.com/rgb-matrix-a ... cuitpython
I try to installing circuit python but when i reboot it appear like a USB drive not as CIRCUITPY
I got also this issue when I try to add the device on the IO platforme following the instruction.
Can you help me
Thanks a lot
Arthur
CircuitPython Metro M4 Airlift lite Issue
- dastels
Re: CircuitPython Metro M4 Airlift lite Issue
CIRCUITPY is a USB drive. When you double-reset to get into the bootloader there should be a METROM4BOOT drive instead.
- Arthur88
hi , yes i know that but its after putting CircuitPython on it, it should reboot as CIRCUITPY.
But it's not the case
Same with the Wippersnap it should appear as Wipper but not for me.
It's just USB drive (D:)
- dastels
Does CIRCUITPY mount if you reset the Metro?
Do you have anything running that would block the drive? Antivirus or such?
- Arthur88
I got this after a reset
- Attachments
- Screenshot 2023-06-06 131955.png (57.73 KiB) Viewed 298 times
- dastels
OK. That looks like the CIRCUITPY drive. Can you put code onto it and have it run?
- Arthur88
Hi, i try again and nothing,
I retry also the IO setup https://io.adafruit.com/Arthur88/device ... uf2/step-2
And again its detect as USB Drive and i don't have the same as the tuto
I should have only 2 files , the wipper boot and the secret files. but i have all of those
it normal ?
i try to continue to see if it connect to the IO platform but no indication on the LED
it normal ?
- Attachments
- Screenshot 2023-06-07 102959.png (40.71 KiB) Viewed 286 times
- Screenshot 2023-06-07 102712.png (69.53 KiB) Viewed 286 times
- Arthur88
Maybe it due to the beta ?
- Attachments
- Screenshot 2023-06-07 112207.png (170 KiB) Viewed 279 times
- dastels
I don't know about wippersnapper. Do you have the correct wippersnapper firmware installed successfully?
I don't know what that beta label is about. I've never had any issue with those boards.
- Arthur88
Ok i try this tuto https://learn.adafruit.com/adafruit-io- ... cuitpython , i install Mu python and the software dont recognize the board , there is a way to hard reset the board ?
- dastels
Did you put the latest CircuitPython on the board?
- Arthur88
yep
- Attachments
- Screenshot 2023-06-08 084221.png (70.22 KiB) Viewed 247 times
- dastels
Try updating the bootloader. Instructions/links are at the bottom of that CircuitPython page.
