I have an Adafruit Audio FX Mini Sound Board - WAV/OGG Trigger - 2MB Flash set up to run via UART with an Arduino Pro Mini. UG is grounded, and RX/TX are both going to the appropriate pins on the Pro Mini. As far as hardware is concerned, everything is the way it should be.
The Pro Mini needs to be able to command the FX board to play specific sound files, as well as adjust the volume. It needs to be able to do this without use of the serial monitor. Unfortunately, the only example for the Adafruit library uses the serial monitor, and I've not had any luck digging into the library to figure things out myself.
I am under the impression that
would tell the FX board to find the WAV file named "TRACK001" and play it, but it doesn't seem to work. It's a total of 11 characters including the filetype.sfx.playTrack("TRACK001WAV");
Is there a list of commands for the Adafruit library readily available and/or are there any examples of using this board through the UART connection that doesn'trequire the use of the serial monitor?
THIS is the only working example I was able to find, and while it was good reference and proof the board can be controlled directly with an Arduino, my issues persist.
