PPS signal from Adafruit GPS unusable by gpsd / ppscheck?
bkloppenborg
Post by bkloppenborg »
I recently purchased the Adafruit Ultimate GPS GNSS with USB - 99 channel w/10 Hz updates (product 4279 April 2023 revision) hoping that it could be used as a ~0.1 ms accurate time source for the computer that I use to operate my mobile telescope setup. Unfortunately, neither `gpsd` or `ppscheck` are able to use the PPS signal on the Ring Indicator (RI) pin. The error I receive is as follows:
sudo ppscheck /dev/ttyUSB0
# Seconds  nanoSecs   Signals
PPS ioctl(TIOCMIWAIT) failed: 25 Inappropriate ioctl for device
The best I can tell, the cp210x driver on Linux doesn't implement the ioctl functions [1] as the `usb_serial_driver.ioctl` function pointer is never populated in the `usb_serial_driver` struct. I find this a bit odd because the CP2102N data sheet [2] states that "All handshaking and modem interface signals" are supported. Does anyone know if this is the case?
While researching this problem, I also uncovered a thread [3] by bjmcculloch indicating that a previous version of the Adafruit Ultimate GPS that used the CP2104 adapter had a similar problem and that there may be an underlying hardware restriction. This is to be contrasted with a new driver I found on GitHub [4] which specifically implements ioctl functions to support PPS signals. Unfortunately, that is for an older kernel.
I'd be interested to know if anyone has gotten this device to work with PPS on `gpsd` and `ppscheck`.
[1] ioctl functions missing from cp210x driver https://github.com/torvalds/linux/blob/ ... l/cp210x.c
[2] cp2102N data sheet https://www.mouser.com/datasheet/2/368/ ... 634912.pdf
[3] cp210x hardware might not support underlying ioctl commands viewtopic.php?p=832544&hilit=Ultimate+GPS+USB+C+pps
[4] Revised cp210x driver https://github.com/fortian/cp210x/tree/master
bkloppenborg
Re: PPS signal from Adafruit GPS unusable by gpsd / ppscheck?
I spent some time investigating this issue further and ended up writing up a blog post on the subject. At the moment, it appears as if GPSD won't be able to use the PPS signal on the Ring Indicator pin because the underlying device driver doesn't expose the right interfaces. To make it work, I believe the driver needs to implement both the usb_serial_driver.tiocmiwait function and usb_serial_driver.process_read_urb. While I was able to figure out how to implement the first function, I have yet to figure out how to properly import the ladder. If anyone wants to pick up where I left off, my post describes how to modify the Silicon Labs driver, build it, and load it.
millercommamatt
Post by millercommamatt »
I just want to say I'm impressed that you used footnotes in a forum post.
rctatar
Post by rctatar »
Brian:
Nice research work and write-up. I also found the device unusable as a stable time source and in my research encountered some of the same references you identified. Looks like you dug a bit longer and deeper -- thank you for doing that.
I have an older device (Ublox 7 series) with a CP2102N USB-to-Serial that seems to properly provide a PPS signal and was very excited to try the newer MediaTek MTK3333 GPS chip with support for more satellites in the Adafruit offering. Obviously it was very sad to find it not work.
I appears that Adafruit needs a new design spin with a different USB-Serial chip to make this work and I'd like to return my purchase.
I'll be experimenting with another device from a different vendor (Ublox 8 series) in the near future.
:Bob
