Errors trying to compile arcada code on CLUE Board
Post Reply
simonspc
Post by simonspc »
I am trying to compile code with the arcada library in the Arduino IDE but am encountering errors even while trying to compile the examples. I am using Arduino IDE 2.2.1 and arcada library version 2.5.7 and getting the following error in all examples.
C:\Users\Pete\Documents\Arduino\libraries\Adafruit_Arcada_Library\Adafruit_Arcada_USBMSD.cpp:9:8: error: 'Adafruit_USBD_MSC' does not name a type; did you mean 'Adafruit_USBD_CDC'?
9 | static Adafruit_USBD_MSC usb_msc;
| Adafruit_USBD_CDC
C:\Users\Pete\Documents\Arduino\libraries\Adafruit_Arcada_Library\Adafruit_Arcada_USBMSD.cpp: In member function 'bool Adafruit_Arcada_SPITFT::filesysBeginMSD(Arcada_FilesystemType)':
C:\Users\Pete\Documents\Arduino\libraries\Adafruit_Arcada_Library\Adafruit_Arcada_USBMSD.cpp:61:5: error: 'usb_msc' was not declared in this scope
61 | usb_msc.setID("Adafruit", "SD Card", "1.0");
C:\Users\Pete\Documents\Arduino\libraries\Adafruit_Arcada_Library\Adafruit_Arcada_USBMSD.cpp:98:5: error: 'usb_msc' was not declared in this scope
98 | usb_msc.setID("Adafruit", "SPI Flash", "1.0");
exit status 1
Compilation error: exit status 1
dastels
Re: Errors trying to compile arcada code on CLUE Board
Post by dastels »
I see this mostly if I have an old library hanging around. Make sure *everything* is up to date: libraries and boards.
During linking, does it complain about multiple copies of a library being found?
simonspc
Post by simonspc »
It doesn't complain about duplicate libraries. I can't find any old libraries hanging around but I will have another look.
dastels
Post by dastels »
Have you updated them using the library manager in Arduino? Just select "Updatable" in the type dropdown.
simonspc
Post by simonspc »
Says it is up to date.
dastels
Post by dastels »
OK..; but all libraries and the relevate board support packages?
Post Reply
Return to “CLUE Board”
