Potentially Faulty AHT20s
- 3w9qlts3h9ww
Hello!
I bought three AHT20 sensor breakout boards, and it seems they could be faulty. I've tried all three with both the adafruit_ahtx0 Python library on a Raspberry Pi, and a Wemos Mini D1 clone flashing with ESPHome. I've attached pictures of the wiring, as well as my ESPHome config and the demonstrated output for each.
I tried each of the three with both setups, but no scenario succeeded. After I tested them all, I also tried them with 5V in, but with the same result. I know the AHT20 chip itself doesn't support it, but the documentation for the Adafruit board says it supports 3-5V, and they had already failed with 3.3V anyway.
The RPI and the D1 board are known to work correctly with other sensors.
Of course I could be doing something wrong, particularly since I haven't used this sensor before, but with a simple I2C interface, I wouldn't think there's much to mess up.
- Attachments
- humidity-1.yaml.txt
- (684 Bytes) Downloaded 2 times
- esphome-out.txt
- (3.76 KiB) Not downloaded yet
- 230914-205440.jpg (59.89 KiB) Viewed 176 times
- 3w9qlts3h9ww
Re: Potentially Faulty AHT20s
Missed some attachments
- Attachments
- PXL_20230914_093734190.jpg (207.79 KiB) Viewed 175 times
- PXL_20230914_093652979.jpg (183.85 KiB) Viewed 175 times
- adafruit_support_carter
Vin should be the same as the logic level for the board:
https://learn.adafruit.com/adafruit-aht ... ns-3064408
Both the Pi and the Wemos are 3.3V logic level boards. Do not connect 5V to Vin.
Try going back to the Raspberry Pi setup, using 3.3V for power on Vin, and then try running an I2C scan:
https://learn.adafruit.com/scanning-i2c ... spberry-pi
Post the scan results here.
- 3w9qlts3h9ww
Hi!
Thanks for clarifying about the voltage.
The chip powers up and is visible, I'm having trouble getting it to communicate. The i2cdetect output is
david@raspberrypi:~ $ i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- 38 -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
The I2C scan looks fine.
If you run the library example:
https://github.com/adafruit/Adafruit_Ci ... pletest.py
immediately after that scan, you get the same code error?
Is the error consistent? It's always an I/O error originating from line 96?
- 3w9qlts3h9ww
Hello Carter!
The call to AHTx0 is consistently failing at line 96 from the Remote I/O OSError. Here's the output from running the whole example script.
(pyenv) david@raspberrypi:~/src/Adafruit_CircuitPython_AHTx0/examples $ python3 ahtx0_simpletest.py
File "/home/david/src/Adafruit_CircuitPython_AHTx0/examples/ahtx0_simpletest.py", line 15, in <module>
sensor = adafruit_ahtx0.AHTx0(i2c)
File "/home/david/pyenv/lib/python3.9/site-packages/adafruit_ahtx0.py", line 96, in __init__
if not self.calibrate():
File "/home/david/pyenv/lib/python3.9/site-packages/adafruit_ahtx0.py", line 114, in calibrate
i2c.write(self._buf, start=0, end=3)
File "/home/david/pyenv/lib/python3.9/site-packages/adafruit_bus_device/i2c_device.py", line 100, in write
self.i2c.writeto(self.device_address, buf, start=start, end=end)
File "/home/david/pyenv/lib/python3.9/site-packages/busio.py", line 202, in writeto
return self._i2c.writeto(address, memoryview(buffer)[start:end], stop=stop)
File "/home/david/pyenv/lib/python3.9/site-packages/adafruit_blinka/microcontroller/generic_linux/i2c.py", line 52, in writeto
self._i2c_bus.write_bytes(address, buffer[start:end])
File "/home/david/pyenv/lib/python3.9/site-packages/Adafruit_PureIO/smbus.py", line 303, in write_bytes
self._device.write(buf)
OSError: [Errno 121] Remote I/O error
And that exact same behavior is being seen with all three AHT20 breakouts?
They show fine in scan. But then fail with same stack trace shown above when trying to run example?
- 3w9qlts3h9ww
Yes, correct.
- adafruit2
carter can you merge and have them test the updated release of
https://github.com/adafruit/Adafruit_Ci ... x0/pull/16
- adafruit2
for arduino, make sure you are running 2.0.5
https://github.com/adafruit/Adafruit_AHTX0/releases
Done. Please try updating to the 1.0.19 release of the library:
https://github.com/adafruit/Adafruit_Ci ... tag/1.0.19
- 3w9qlts3h9ww
The update worked, thank you!
Cool. Glad that fixed it.
Is it working on Arduino as well? Or whatever you were using on the ESPHome setup. As mentioned above, the Arduino library needs to be latest to also fix the same underlying issue.
- 3w9qlts3h9ww
No, it's a D1 clone, and I think the component module is part of ESPHome, rather than using a library. I put in a bug report to see about getting it updated: https://github.com/esphome/issues/issues/4899
OK, that looks good. Sounds like in the ESPhome case they have their own separate copy of the driver. So that's the correct place to open the issue. Hopefully the fix there can be as simple as the patch to the Arduino lib.
