Circuit Playground Express not appearing
- fsbilimoria
I recently bought a CPX, and the bootloader folder won't show up on the computer. I am using a data cable and tried on different usb ports. Upon plugging the board in, the neopixels do the rainbow animation, but when I press reset (whether singly or doubly), the rainbow colors freeze and the solid green never appears.
- adafruit_support_carter
Re: Circuit Playground Express not appearing
Double check that you have a CP Express:
https://www.adafruit.com/product/3333
And not a CP Classic:
https://www.adafruit.com/product/3000
or CP Bluefruit:
https://www.adafruit.com/product/4333
How to tell:
https://learn.adafruit.com/adafruit-cir ... vs-express
or CP Bluefruit:
How to tell:
- fsbilimoria
Definitely an express, as seen in pic
- Attachments
- 20231110_012459.jpg (971.75 KiB) Viewed 232 times
Yep. That's an Express. Thanks for verifying.
After double pressing the reset button, the NeoPixel ring on the CPX should light up. Is it red or green?
- fsbilimoria
Neither: the rainbow animation freezes and does not change
(edit: good lord I did not realize these photos would turn out so huge)
- Attachments
- 20231111_031134.jpg (499.46 KiB) Viewed 218 times
That's acting like it's not seeing the double press. Have you tried multiple times with different timings of pressing the reset button twice? Sometimes the cadence can be tricky to get.
- fsbilimoria
Yes, I've tried slower and faster with the same result
OK. It can be tricky sometimes, but shouldn't be that bad.
What operating system are you running?
Does the PC respond at all when the CPX is plugged in? Like make a "something connected" noise?
- fsbilimoria
Windows 11. The computer does make the connected sound when I plug it in, and then the disconnect sound on the first button press
Having the sound is promising. At least the PC is seeing the CPX and doing something.
There are some known reasons for the folders not showing up. Read through here and see if any of them might apply to your setup:
https://learn.adafruit.com/welcome-to-c ... leshooting
As another potential simple check - if you have access to another PC, see if the CPX will show up there. Use the same USB cable, etc. so it's only the PC that is different.
- fsbilimoria
Sorry this response took a while. I tried it on another computer I've used with circuit python boards, and got the same result.
Going back to this - what shows up in Device Manager after plugging it in but *before* pressing reset.Windows 11. The computer does make the connected sound when I plug it in, and then the disconnect sound on the first button press
- petespaco
Just for grins, maybe try a different USB data cable?
- fsbilimoria
I have also tried multiple known data cables.
In Device Manager, a port appears as "USB Serial Device (COM10)". A "USB Composite Device" also appears under USB controllers. There could be others in the other categories, but those are the most obvious. They both disappear after hitting reset.
What's your goal for programming the CPX? Are you planning to use Arduino? CircuitPython? MakeCode?
How are you getting the rainbow animation to start again once it stops? It sounds like any pressing of reset causes it to freeze
So at this point, if you press reset again, it just stays frozen?when I press reset (whether singly or doubly), the rainbow colors freeze and the solid green never appears.
