Hello all,
Thanks in advance for any help you can give. I have purchased all of the products for the https://learn.adafruit.com/stream-deck- ... dafruit-io project. The issue that I am having is in the compilation of the code to upload. I was able to compile and upload once. It had the wrong SSID and I changed it, but I cannot reupload it. It keeps failing to compile and I do not know why. I have deleted the messagepanel.ino and config.h and created new ones. I have updated the bootloader. I have checked that all libraries are updated, etc. Below are the errors on compile:
In file included from c:\Users\DiggerEOD\BANNED\Documents\Arduino\libraries\Adafruit_IO_Arduino\src/AdafruitIO_WiFi.h:31,
from C:\Users\DiggerEOD\BANNED\Documents\Adafruit\Projects\MessagePanel\config.h:36,
from C:\Users\DiggerEOD\BANNED\Documents\Adafruit\Projects\MessagePanel\MessagePanel.ino:35:
c:\Users\DiggerEOD\BANNED\Documents\Arduino\libraries\Adafruit_IO_Arduino\src/wifi/AdafruitIO_AIRLIFT.h: In member function 'void AdafruitIO_AIRLIFT::setLEDs(uint8_t, uint8_t, uint8_t)':
c:\Users\DiggerEOD\BANNED\Documents\Arduino\libraries\Adafruit_IO_Arduino\src/wifi/AdafruitIO_AIRLIFT.h:110:56: error: 'class WiFiClass' has no member named 'setLEDs'
110 | void setLEDs(uint8_t r, uint8_t g, uint8_t b) { WiFi.setLEDs(r, g, b); }
c:\Users\DiggerEOD\BANNED\Documents\Arduino\libraries\Adafruit_IO_Arduino\src/wifi/AdafruitIO_AIRLIFT.h: In member function 'virtual void AdafruitIO_AIRLIFT::_connect()':
c:\Users\DiggerEOD\BANNED\Documents\Arduino\libraries\Adafruit_IO_Arduino\src/wifi/AdafruitIO_AIRLIFT.h:176:14: error: 'class WiFiClass' has no member named 'setPins'
176 | WiFi.setPins(_ssPin, _ackPin, _rstPin, _gpio0Pin, _wifi);
exit status 1
Compilation error: exit status 1
I'm brand new to this and am looking for some guidance.
N00b: Metro M4 Airlift Lite and cannot compile Adafruit code
- DiggerEOD
- dastels
Re: N00b: Metro M4 Airlift Lite and cannot compile Adafruit code
It does look like a library mismatch issue. Do you have multiple copies of Adafruit_IO_Arduino on your system? If so it could be picking up an older one.
- DiggerEOD
@dastels - I searched in the Library Manager for "IO" and I have Adafruit BusIO (1.14.5) and Adafruit IO Arduino (4.2.9).
Here's a screenshot of all of libraries in the Arduino folder.
- dastels
If it's the case, then you'd have copies of the library in multiple places in your filesystem. The problem arises when there's a copy outside the library manager's scope that the build tools pickup on.
- DiggerEOD
@dastels - Thank you for your help on this. I was able to get the sketch to compile and upload to the Metro M4 Airlift after I uninstalled/deleted everything associated to this project.
On a seperate note that I hope you can assist with:
I have the 32x32 panel and the messages are not centered on the panel. Would you happen to know how to fix this?
Any thoughts?
Any thoughts?
- Attachments
- Screen Shot 2023-11-21 at 11.20.53 AM.png (59.05 KiB) Viewed 33 times
- Screen Shot 2023-11-21 at 11.14.54 AM.png (17.36 KiB) Viewed 33 times
- dastels
Glad it's working. Can you make a new thread for the new issue? It's better if a replacement is required, and it will get more/fresh eyes on it.
