1788 mp3 music maker shield
Post Reply
JUNN2322
Post by JUNN2322 »
Hi I'm going to use this board https://www.adafruit.com/product/1788 along with my arduino uno and then a mpr121 like this one:https://www.adafruit.com/product/1982(but not the same one).
And this is the website i follow: https://www.youtube.com/watch?v=tiz4bSmrVjM
adafruit_support_mike had said that the VS1053 has a register named SCI_BASS which controls bass and treble algorithms in the on-chip DSP. The Adafruit library doesn't have any functions to set them, so that's a "for advanced users" . The VS1053 doesn't have any onboard support for reverb.
However, I'm a beginner, can you give me a code which can adjust the bass, treble, and volume?
mikeysklar
Re: 1788 mp3 music maker shield
Post by mikeysklar »
See pg. 41 of the VS1053 datasheet.
Screenshot 2023-11-20 at 1.22.54 PM.png (52.57 KiB) Viewed 142 times
For example setting SCI_BASS to 0x00f6 will have 15 dB enhancement below 60 Hz.
#define SCI_BASS  0x00f6
JUNN2322
Post by JUNN2322 »
mikeysklar wrote: Mon Nov 20, 2023 5:23 pm See pg. 41 of the VS1053 datasheet.
Thanks for your reply! Can you share a complete code? I'm afraid I have to learn step by step. After all, I'm a beginner. Hope to get your reply
mikeysklar
The SCI_BASS parameter is the only parameter to modify. There are some further details in the VS1053 datasheet, but that is the extent of it.
Post Reply
