I followed the tutorial at https://learn.adafruit.com/ble-hid-keyb ... s-and-code using the ItsyBitsy NRF52840 Express. It worked, but only when it was connected to a USB port on a PC and a data connection was made. I tried powering it with a few different TP4056 modules, a 3.7V lipo battery pack, and several USB chargers and got no BLE activity at all. BLE worked consistently after mounting the device or using cat to display serial output. It successfully connected to every device I had available, and the buttons worked as expected.
I also tested the device using an arduino sketch with similar BLE keyboard capabilities, and the problem remained.
I'm not sure what else to try at this point. Any ideas or pointers would be welcome.
ItsyBitsy NRF52840 Express - BLE Keyboard issues
- williecorto
- mikeysklar
Re: ItsyBitsy NRF52840 Express - BLE Keyboard issues
Can you run try a simple blink example to see if CircuitPython is running correctly when powered by a "dumb" USB plug or a LiPo?
Is there anything else connected to the ItsyBitsy?
import board
import digitalio
import time
led = digitalio.DigitalInOut(board.LED)
led.direction = digitalio.Direction.OUTPUT
while True:
led.value = True
time.sleep(0.5)
led.value = False
time.sleep(0.5)
- williecorto
Thanks for replying.
I have two buttons attached to pins 10 and 11 with a 10k pull up resistor on each button going back to the 3v pin, and I have a TP4056 module attached to bat and ground. Blinking the LED works when powered by the TP4056 module or a USB charger.
- mikeysklar
Thank you for doing the blink test.
What version of CircuitPython and library bundle are you running?
Are you able to run the example code unmodified without any buttons attached to the ItsyBitsy while over USB? If that works can you try the same thing on USB or battery power?
A few of these simple experiments should help pin down where the issue is coming from.
- williecorto
It's currently running Circuitpython 8.2.7 with the 8x bundle. I also tried 9.0.0-alpha4 with similar results.
The unmodified script isn't really useful for testing here, so I adjusted it to send keystrokes automatically when connected. But I found that it exhibited the same behavior after the buttons were removed.
Perhaps it's time to try a new board.
Thanks again.
Thanks again.
- mikeysklar
Looking at the guide for the ItsyBitsy nRF52840 Express there is a final page about a known bug with using the high speed SPI interface from a Battery. That is pretty different from your BLE not working with battery, but worth acknowledging.
Can you post a photo of how you are connecting the battery and charging modules? This chip wants to be connected?
Are you current on the bootloader 0.7.0?
- williecorto
I had desoldered the first device by the time I read this post, so I don't have any pics of that to share. But I have gone on to purchase another ItsyBitsy NRF52840 express, a Seeed Studio XIAO nRF52840 Sense, and a Feather nRF52840 Express as was used in the original project. All three devices exhibit the exact same behavior when powered via gpio bat/gnd or USB without data (i.e. USB power adapter or a 'power only' cable). I have tried bootloaders 0.7.0 and 0.8.0 on all three Adafruit boards, and 0.8.0 on the Seeed device.
I did misstate the problem in an earlier post, but only slightly. The devices all advertise / connect / pair to any ble capable central device like an Android phone or a PC when powered by any source. But they only send keystrokes when connected via USB to a PC. I don't have the proper JST connector for the port on the Feather Express, but a few of those should arrive today. So I plan to try that when I get home this evening.
This is the Feather Express connected to a 3.7v lipo: https://imgur.com/fcOJhcz
- mikeysklar
I can try to reproduce your issue if you want to provide some minimum viable code to start with.
- williecorto
That would be most welcome, as I can't help feeling that I may be missing something important. Thank you.
The current script has been trimmed down a bit, and just sends (or is supposed to send) "q" repeatedly.
import time
import board
from digitalio import DigitalInOut, Direction, Pull
import adafruit_ble
from adafruit_ble.advertising import Advertisement
from adafruit_ble.advertising.standard import ProvideServicesAdvertisement
from adafruit_ble.services.standard.hid import HIDService
from adafruit_ble.services.standard.device_info import DeviceInfoService
from adafruit_hid.keyboard import Keyboard
from adafruit_hid.keyboard_layout_us import KeyboardLayoutUS
from adafruit_hid.keycode import Keycode
hid = HIDService()
device_info = DeviceInfoService(software_revision=adafruit_ble.__version__,
manufacturer="Adafruit Industries")
advertisement = ProvideServicesAdvertisement(hid)
advertisement.appearance = 961
scan_response = Advertisement()
scan_response.complete_name = "CircuitPython HID"
ble = adafruit_ble.BLERadio()
k = Keyboard(hid.devices)
# Start Advertising
if not ble.connected:
ble.start_advertising(advertisement, scan_response)
# Main Loop
while True:
k.send(Keycode.Q)
time.sleep(0.5)
- mikeysklar
Okay, this is a good start. If I can repeat this tomorrow with my ItsyBitsy nRF52840 we can start a github issue.
- mikeysklar
I was able to reproduce the issue you are seeing.
My ItsyBitsy had a legacy bootloader 0.2.13.
I updated with the Arduino IDE to 0.6.2 and manual drop of the UF2 image to 0.8.0.
Ran you minimum viable code with:
Executes without output to REPL and once paired with iOS device when I touch the bottom text input box I see the q's.
As soon as I move the micro-USB data cable I'm power the ItsyBitsy with from my computer to a "dumb wall plug" I'm no longer able to see the characters transfer.
Looks like a viable issue for the CircuitPython github repo. Are you comfortable opening it or would you like me to?
sklarm@grazie Downloads % cat /Volumes/ITSY840BOOT/INFO_UF2.TXT
UF2 Bootloader 0.8.0 lib/nrfx (v2.0.0) lib/tinyusb (0.12.0-145-g9775e7691) lib/uf2 (remotes/origin/configupdate-9-gadbb8c7)
Model: Adafruit ItsyBitsy nRF52840 Express
Board-ID: nRF52840-ItsyBitsy-revA
Date: Sep 29 2023
SoftDevice: S140 6.1.1
CircuitPython 8.2.8
Lib Bundle: 2023-11-16 for adafruit_ble + adafruit_hid
- williecorto
I have created a bug report for the issue. Thank you for taking the time to reproduce it.
https://github.com/adafruit/circuitpython/issues/8672
