Page 1 of 1
EINK Service start issue (with fix/hack)
Posted: Sun Oct 30, 2016 9:10 pm
by frooty4adafruit
Hi everybody,
I had issues getting the EInk Display service to start. The reason was that it assumed 'mkdir' was in /usr/bin, when in fact it was in /bin on my pi.
I manually altered the following file to reflect the change:
/usr/lib/systemd/system/epd-fuse.service
Also, it should be noted that in the tutorial, Adafruit recommends using a previous build on github, which is unfortunately not available. Fornutately, however, it doesn't appear to be necessary! The demo code worked fine with some small tweaks-- I had to change directories in the python demo code to match directories on the pi.
Re: EINK Service start issue (with fix/hack)
Posted: Mon Oct 31, 2016 10:49 am
by adafruit2
thx, added to guide FAQ!
