PWM Servo Hat Overheating
- orcam
This is re: Order Confirmation No: 1254250-4140382363, and related to 1 x Adafruit 16-Channel PWM / Servo HAT for Raspberry Pi - Mini Kit[ID:2327]
This is what happened:
- Setup and solder the pins as directed. Solder connections look good
- Connected the board to Raspberry Pi2, plugged in 5v 4A supply bought from Adafruit, and went through the tutorial. i2cdetect finds it and confirms address 0x40.
- Attached one servo to channel 0, and run Servo_Example.py. The servo didn't move. Changed the frequency setting to 100Hz, instead of 60Hz
- While trying to debug this, after 5mins or so, there was the unmistakable components burning smell. The MOSFET was extremely hot.
- Did a short check, and now +5 and GND pins show shorted, I suspect the MOSFET is burned and shorting power and ground.
I send a mail to support@ and they suggested I should post to this forum.
Thanks in advance for the help.
Re: PWM Servo Hat Overheating
Please post photos showing your soldering and connections to the HAT.
- orcam
Here are the pictures.
If power/ground is shorted because of soldering, it would just load the power supply, the MOSTFET would not be damaged. I think something else happened and MOSFET burned, shorting power/ground on the board.- adafruit_support_bill
Given that all of the current flows through it, a short between V+ and ground could definitely overload the MOSFET.If power/ground is shorted because of soldering, it would just load the power supply, the MOSTFET would not be damaged.
When you initially plugged in the power supply did the green LED light up?
- orcam
Yes, the green LED lighted up. Even now it lights up, but the MOSFET gets very hot in seconds.
It is not a dead-short then, since you still have a voltage drop through the led. We can try replacing the HAT. Please contact [email protected] with a link to this thread.
- Roark
I'm having the same exact problem, was there ever a solution found, or should I email support?
@Roark - Please post photos showing your soldering and connections to the HAT.
- Roark
The hat has been working fine for several weeks, and I haven't soldered anything new to it recently.
- IMG_0236.JPG (146.8 KiB) Viewed 522 times
- IMG_0235.JPG (136.21 KiB) Viewed 522 times
What are you using to power the servos?
Does the green led illuminate when you the power connected?
What servos are you using, and how many?
- Roark
I'm using a switching ac/dc power adapter, the model number is GEO151UB-5025. The green LED does turn on, and I'm using two tower pro SG92R micro servos. Thanks for the quick replies.
Do you have any specifications for that power supply? I searched a bit and only found input specs. Nothing about the output.
- Roark
I bought it from adafruit, here's the link: https://www.adafruit.com/product/276
And when did you purchase the PWM Servo HAT?
- Roark
On 1/30/2016, the order ID is: 1003419-2118688374
