long range sensor
- aasiyah
long range sensor
suggest me some long range distance sensor of about 7-10m or more than that which can sense humans and compatible with raspberry pi?
Re: long range sensor
Those are pretty vague requirements. You could use a PIR sensor to sense movement of warm-blooded mammals at that distance. A LIDAR system could detect any sizeable object moving in that range. You could set up break-beam sensors around a perimeter and detect when any object passes through them. A camera with image processing software could be programmed for face detection. Any of the above could work with a Pi.
