INA260 current sensor library
by tronicgr on Mon May 01, 2017 11:14 pm
I needed the INA260 for a project but couldn't find anywhere a arduino library for it. So i decided to write one myself. Well, not exactly from scratch, i used the Adafruit INA219 as base, replaced the new register locations and conversion calculations. Anyway, after a few hours the new library is ready and tested. Works great. Some functions are missing, but it can measure the voltage and the current perfectly. I used the TI's evaluation board for testing: https://youtu.be/8NWVv__e6lM
The library can be found here:
https://github.com/tronicgr/INA260-current-sensor
I wish Adafruit would start making a breakout for these INA260 sensors, they are amazing for what they can do. And of course i won't mind if parts or even the whole the library i shared above was used for the breakouts.
Its the least contribution i can do for Adafruit, whose breakout boards literaly helped so many times fast prototyping on my projects!
Thanos
tronicgr
Re: INA260 current sensor library
by adafruit_support_bill on Tue May 02, 2017 5:58 am
Thank you for the suggestion. I will forward it to the design team.
by tronicgr on Tue Oct 17, 2017 11:45 am
I just shared a new arduino library for a different battery current/gauge sensor that is perfect for portable applications.
https://github.com/tronicgr/MAX17055-cu ... uge-sensor
I hope that helps.
Thanos
tronicgr
by adafruit_support_bill on Tue Oct 17, 2017 12:20 pm
Great! Thank you for sharing your code.
by eastpole on Fri May 03, 2019 11:36 am
Great suggestion for a product, Thanos. The INA260 breakout is now available from Adafruit:
https://www.adafruit.com/product/4226
Yaaaay! I'm going to wire up a solar panel and measure what it puts into a battery.
eastpole
by bartgrefte on Sat Jul 20, 2019 1:28 pm
How do you modify the example in the library to be able to use multiple INA260 breakout boards? Looks to me the library is specifically written for using the default address.
bartgrefte
by adafruit_support_bill on Sat Jul 20, 2019 1:53 pm
The 'begin' function in the library takes an optional address. Just specify the alternate address for the second instance.
  boolean begin(uint8_t i2c_addr=INA260_I2CADDR_DEFAULT, TwoWire *theWire = &Wire);
by bartgrefte on Mon Jul 22, 2019 7:21 am
adafruit_support_bill wrote:The 'begin' function in the library takes an optional address. Just specify the alternate address for the second instance.
I guess I need to change
Adafruit_INA260 ina260 = Adafruit_INA260();
for that? https://learn.adafruit.com/adafruit-ina ... t?view=all doesn't show anything about this, the option of changing the I2C-address (those solder jumpers or whatever they are called) isn't even mentioned.
bartgrefte
by adafruit_support_bill on Mon Jul 22, 2019 8:13 am
Not the constructor - the begin() function. Assuming that you create 2 instances: ina260_A and ina260_B, your setup code would be something like:
if (!ina260_A.begin())
   Serial.println("Couldn't find INA260 chip - A");
   while (1);
if (!ina260_B.begin(0x41))
   Serial.println("Couldn't find INA260 chip - B");
   while (1);
Both address jumpers are pulled to GND by default. If you bridge them, they are pulled to VS. So bridging A0 gives you address 0x41.
See Table 2 on page 17 of the data sheet.
http://www.ti.com/lit/ds/symlink/ina260.pdf
by bartgrefte on Mon Jul 22, 2019 12:16 pm
Ah, thanks :), that got me going, now reading two INA260's on the same Arduino.
bartgrefte
by JM_Tech on Wed Jul 24, 2019 6:37 am
I am bridging A0 as described here and I am still only getting address 0x40. Any example would be helpful as I have been struggling with this for hours now.
*****Scratch That******
I was 1 pin off and did not realize it... even after I checked with the meter... Facepalm moment
JM_Tech
