Need help with sim reader software
by mavoclithrian on Fri Aug 14, 2009 8:25 pm
I bought and assembled the sim card reader, but the software doesn't seem to be working. Is there something I can try?? The Error log it tells me to look at says this:
File "pySimReader.py", line 30, in <module>
File "zipextimporter.pyc", line 82, in load_module
File "wx\__init__.pyc", line 45, in <module>
File "wx\_core.pyc", line 4, in <module>
File "zipextimporter.pyc", line 98, in load_module
ImportError: MemoryLoadLibrary failed loading wx\_core_.pyd
mavoclithrian
Re: Need help with sim reader software
by adafruit on Fri Aug 14, 2009 9:48 pm
what os are you using
by mavoclithrian on Sat Aug 15, 2009 10:38 pm
I was trying an older XP, because it has a serial port. If I bought a USB adapter I could switch to Vista, but I'd only do that if it would fix the error.
mavoclithrian
by mavoclithrian on Sat Aug 15, 2009 10:50 pm
Do I need this python thing I hear about or is there another way to solve this error??
mavoclithrian
by adafruit on Sat Aug 15, 2009 11:30 pm
are you running the .exe? how much RAM does the machine have?
by mavoclithrian on Mon Aug 17, 2009 10:02 am
Yes I'm running the .exe, this particular machine has 1GB of ram, but like I said I could always get a USB adapter and go to my machine which has 4GB of ram & vista. What language did you program the .exe in, because I was thinking of loading the source code into visual studio and try to debug??
mavoclithrian
by adafruit on Mon Aug 17, 2009 12:07 pm
its in python
you can download just the script, and install python 2.5 and the extra libraries
dont quite know why its freaking. are you admininstrator?
by mavoclithrian on Tue Aug 18, 2009 4:24 pm
I am the admin, but I wasn't trying the software on that account, So that could be the reason.
mavoclithrian
by mavoclithrian on Wed Aug 26, 2009 11:03 am
Okay so I tried it on an admin account and it gave me the same error message. I also tried installing python, but either the version I got was bad or it only worked with 64 bit computers (I'm using a 32 bit computer). Any light you can shed on the matter would be appreciated.
mavoclithrian
by adafruit on Wed Aug 26, 2009 11:43 am
what happened when you tried to install python?
by mavoclithrian on Thu Aug 27, 2009 11:45 am
The .exe error told me I needed a 64 bit computer to run it. If you could give me a hyperlink to the 32 bit version that would help a lot.
mavoclithrian
by adafruit on Thu Aug 27, 2009 12:02 pm
you probably downloaded the wrong version. python definately runs on 32bit arch
by schnee72 on Fri Oct 02, 2009 3:13 am
With vista64 I got the same errors that were listed in the original post using the windows executable. I downloaded the source zip file and was able to run pysimreader from the command line with a 32bit version of python, pyserial, and a 32 bit version of wxpython (it would not work with 64 bit versions). I just thought I would mention it here in case someone else ran into a similar problem.
schnee72
by SchippStrich on Tue Nov 03, 2009 9:56 am
Download this file:
http://www.dll-files.com/dllindex/dll-f ... ml?msvcp71
And place it in the PySim directory, you should be good to go now!
Taken from this:
http://forum.opensubtitles.org/viewtopic.php?
SchippStrich
