How long does Xbee pro 63mw wire antenna receives/transmits?
- giorgio_new
Hello, I have bought an Xbee pro 63 mW wire antenna. I have it inside a plastic box, do you know what is the maximum distance it can send/receive data?
- Franklin97355
Re: How long does Xbee pro 63mw wire antenna receives/transm
That depends on what it is sending to or receiving from as well as the objects in between. The datasheets should give you more information but testing id the only way to know if it will work for your project.
