Does anyone know what happened to MDC Japan?
Chat about pick and place machines, reflow ovens, assembly techniques and other SMT tips & trix
mikeanton
Re: Does anyone know what happened to MDC Japan?
Post by mikeanton »
You should be able to scan a square part using the laser without problems. There is nothing to prevent square parts from being used, but if the part is rectangular, then the long side should be scanned first. You may need to relax the tolerance settings. Try to use 50%, and see if it works any better.
If the pins are very thin, you may not be able to use the pins for alignment. In that case, hopefully scanning the body is good enough.
Return to “SMT (Surface Mount Tech)”
