dht 11 not working pi 4
osoblanco84
Post by osoblanco84 »
i have tried everything on the forums and nothing is working and wondering if it can even work. keep getting error
File "/home/pi/humidity.py", line 7, in <module>
humidity, temperature = Adafruit_DHT.read_retry(DHT_SENSOR, DHT_PIN)
File "/usr/local/lib/python3.7/dist-packages/Adafruit_DHT/common.py", line 94, in read_retry
humidity, temperature = read(sensor, pin, platform)
File "/usr/local/lib/python3.7/dist-packages/Adafruit_DHT/common.py", line 80, in read
platform = get_platform()
File "/usr/local/lib/python3.7/dist-packages/Adafruit_DHT/common.py", line 60, in get_platform
from . import Beaglebone_Black
File "/usr/local/lib/python3.7/dist-packages/Adafruit_DHT/Beaglebone_Black.py", line 24, in <module>
from . import Beaglebone_Black_Driver as driver
ImportError: cannot import name 'Beaglebone_Black_Driver' from 'Adafruit_DHT' (/usr/local/lib/python3.7/dist-packages/Adafruit_DHT/__init__.py)
Ive done ever update possible
dastels
Re: dht 11 not working pi 4
Post by dastels »
For some reason it thinks it's running on a Beaglebone Black. Which is odd, based on reading through the code.
Please post the contents of /usr/local/lib/python3.7/dist-packages/Adafruit_DHT/platform_detect.py
Also the output from
cat /proc/cpuinfo
osoblanco84
Sorry if i don't post this right
import platform
import re
# Platform identification constants.
UNKNOWN          = 0
RASPBERRY_PI     = 1
BEAGLEBONE_BLACK = 2
def platform_detect():
    """Detect if running on the Raspberry Pi or Beaglebone Black and return the
    platform type.  Will return RASPBERRY_PI, BEAGLEBONE_BLACK, or UNKNOWN."""
    # Handle Raspberry Pi
    pi = pi_version()
    if pi is not None:
        return RASPBERRY_PI
    # Handle Beaglebone Black
    # TODO: Check the Beaglebone Black /proc/cpuinfo value instead of reading
    # the platform.
    plat = platform.platform()
    if plat.lower().find('armv7l-with-debian') > -1:
        return BEAGLEBONE_BLACK
    elif plat.lower().find('armv7l-with-ubuntu') > -1:
    elif plat.lower().find('armv7l-with-glibc2.4') > -1:
    elif plat.lower().find('armv7l-with-arch') > -1:
    # Couldn't figure out the platform, just return unknown.
    return UNKNOWN
def pi_revision():
    """Detect the revision number of a Raspberry Pi, useful for changing
    functionality like default I2C bus based on revision."""
    # Revision list available at: http://elinux.org/RPi_HardwareHistory#Board_Revision_History
    with open('/proc/cpuinfo', 'r') as infile:
        for line in infile:
            # Match a line of the form "Revision : 0002" while ignoring extra
            # info in front of the revsion (like 1000 when the Pi was over-volted).
            match = re.match('Revision\s+:\s+.*(\w{4})$', line, flags=re.IGNORECASE)
            if match and match.group(1) in ['0000', '0002', '0003']:
                # Return revision 1 if revision ends with 0000, 0002 or 0003.
                return 1
            elif match:
                # Assume revision 2 if revision ends with any other 4 chars.
                return 2
        # Couldn't find the revision, throw an exception.
        raise RuntimeError('Could not determine Raspberry Pi revision.')
def pi_version():
    """Detect the version of the Raspberry Pi.  Returns either 1, 2, 3 or
    None depending on if it's a Raspberry Pi 1 (model A, B, A+, B+),
    Raspberry Pi 2 (model B+), Raspberry Pi 3,Raspberry Pi 3 (model B+) or not a Raspberry Pi.
    # Check /proc/cpuinfo for the Hardware field value.
    # 2708 is pi 1
    # 2709 is pi 2
    # 2835 is pi 3
    # 2837 is pi 3b+
    # Anything else is not a pi.
        cpuinfo = infile.read()
    # Match a line like 'Hardware   : BCM2709'
    match = re.search('^Hardware\s+:\s+(\w+)$', cpuinfo,
                      flags=re.MULTILINE | re.IGNORECASE)
    if not match:
        # Couldn't find the hardware, assume it isn't a pi.
        return None
    if match.group(1) == 'BCM2708':
        # Pi 1
        return 1
    elif match.group(1) == 'BCM2709':
        # Pi 2
        return 2
    elif match.group(1) == 'BCM2835':
        # Pi 3
        return 3
    elif match.group(1) == 'BCM2837':
        # Pi 3b+
        return 3
    else:
        # Something else, not a pi.
        return None
from terminal
processor	: 0
model name	: ARMv7 Processor rev 3 (v7l)
BogoMIPS	: 342.00
Features	: half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
CPU implementer	: 0x41
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xd08
CPU revision	: 3
processor	: 1
BogoMIPS	: 342.00
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xd08
CPU revision	: 3
processor	: 2
BogoMIPS	: 342.00
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xd08
CPU revision	: 3
processor	: 3
BogoMIPS	: 342.00
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xd08
CPU revision	: 3
Hardware	: BCM2711
Revision	: c03112
Serial		: 100000005e2ae97c
Model		: Raspberry Pi 4 Model B Rev 1.2
dastels
Post by dastels »
Thanks. That shows the problem.
Interesting... your Pi4 Model B is Rev 1.2 and has a BCM2711. My Rev 1.1 identifies as having a BCM2835.
The platform detect code isn't accounting for this (assumedly) recent change. I'll raise this as something to be fixed. But for now, you can edit /usr/local/lib/python3.7/dist-packages/Adafruit_DHT/platform_detect.py to fix it. In the pi_version function at the end of the file, make the following addition:
        # Pi 3 or Pi 4
        return 3
    ### start of addition
    elif match.group(1) == 'BCM2711':
        # Pi 4
        return 3
    ### end of addition
        # Pi 3b+
        return 3
That should do it. Let me know if it does and I'll do a PR for the fix.
osoblanco84
I've tried editing the file but i keep getting an error that it looks like this file isn't writable.
osoblanco84
Sorry new to Linux and pi's forgot sudo nano. got it done fully working now thanks so much.
taveresc
Post by taveresc »
Thanks for the fix. Helped me. Strange, that the Rasp 4 is missing. I updated the Adafruit_DHT package just a few days ago. adafruit should consider updating it.
alfi_italy
Post by alfi_italy »
I had the same problem yesterday - after Update/Upgrade Raspian on Pi4 my program did recognize DHT22 anymore.
The fix described above solved it.
Thanks.
Return to “Beagle Bone & Adafruit Beagle Bone products”
