I am unable to use the RTC PFC8523. i am getting the following in the dmesg:
pi@raspberrypi:~ $ dmesg | grep rtc
[ 5.725960] rtc-pcf8523 1-0068: failed to set xtal load capacitance: -121
[ 5.726604] rtc-pcf8523: probe of 1-0068 failed with error -121
PCF8523 Error in dmesg
- adafruit_support_carter
Re: PCF8523 Error in dmesg
Please post a photo of your setup showing how everything is connected.
- Jizobizo
Using 5 volt for VCC.
- rtc3.jpg (194.34 KiB) Viewed 1564 times
- rtc2.jpg (309.1 KiB) Viewed 1564 times
- rtc1.jpg (219.46 KiB) Viewed 1564 times
Try switching to 3V for VCC. The Pi is a 3V board.
https://learn.adafruit.com/adafruit-pcf ... -2933148-3
- Jizobizo
I get the same thing on 3 volt, but i will try again and see. Also, if this is only a 3 volt item then you need to change the description.
"Equipped with PCF8523 RTC - it can run from 3.3V or 5V power & logic!"
https://www.adafruit.com/product/3295
It's not 3V only. But you need to match power to your board's logic level. From link above.
In your case, it's 3.3V.This chip can be powered by 3-5VDC so there is now on-board regulator. To power the board, give it the same power as the logic level of your microcontroller - e.g. for a 5V micro like Arduino, use 5V
- Jizobizo
adafruit_support_carter wrote:It's not 3V only. But you need to match power to your board's logic level. From link above.In your case, it's 3.3V.This chip can be powered by 3-5VDC so there is now on-board regulator. To power the board, give it the same power as the logic level of your microcontroller - e.g. for a 5V micro like Arduino, use 5V
Ahh gotcha. I have it on 3.3v pin and i am not showing ID #68 in my i2cdetect output:
pi@raspberrypi:~ $ sudo i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
I have confirmed the voltage on the rtc and it matches whats coming out of the pi. Could i have hosed it when connecting to 5v??
- Jizobizo
This is what i get when i did a full restore, before and after adding the dtoverlay=i2c-rtc,pcf8523 to the config.txt. This is on both a rpi 3b+ and a 4 4gb:
pi@raspberrypi:~ $ sudo i2cdetect -y 0
Error: Could not open file `/dev/i2c-0' or `/dev/i2c/0': No such file or directory
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.4.72-v7l+ (dom@buildbot) (gcc version 9.3.0 (Ubuntu 9.3.0-17ubuntu1~20.04)) #1356 SMP Thu Oct 22 13:57:51 BST 2020
[ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000001ec00000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] On node 0 totalpages: 1012736
[ 0.000000] DMA zone: 2304 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 196608 pages, LIFO batch:63
[ 0.000000] HighMem zone: 816128 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 20 pages/cpu s49804 r8192 d23924 u81920
[ 0.000000] pcpu-alloc: s49804 r8192 d23924 u81920 alloc=20*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1010432
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 smsc95xx.macaddr=DC:A6:32:73:60:02 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty3 consoleblank=0 loglevel=0 root=PARTUUID=38df017e-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x17cc0000-0x1bcc0000] (64MB)
[ 0.000000] Memory: 3655588K/4050944K available (10240K kernel code, 745K rwdata, 2836K rodata, 2048K init, 856K bss, 133212K reserved, 262144K cma-reserved, 3264512K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 31086 entries in 61 pages
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] random: get_random_bytes called from start_kernel+0x338/0x520 with crng_init=0
[ 0.000008] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000023] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000102] bcm2835: system timer (irq = 17)
[ 0.000750] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000765] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000781] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000793] Switching to timer-based delay loop, resolution 18ns
[ 0.001028] Console: colour dummy device 80x30
[ 0.001061] printk: console [tty3] enabled
[ 0.001115] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[ 0.001136] pid_max: default: 32768 minimum: 301
[ 0.001285] LSM: Security Framework initializing
[ 0.001476] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.001499] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.002766] Disabling memory control group subsystem
[ 0.002887] CPU: Testing write buffer coherency: ok
[ 0.003397] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.004316] Setting up static identity map for 0x200000 - 0x20003c
[ 0.004524] rcu: Hierarchical SRCU implementation.
[ 0.005203] smp: Bringing up secondary CPUs ...
[ 0.006400] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.007728] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.008995] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.009152] smp: Brought up 1 node, 4 CPUs
[ 0.009168] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.009181] CPU: All CPU(s) started in HYP mode.
[ 0.009193] CPU: Virtualization extensions available.
[ 0.010015] devtmpfs: initialized
[ 0.023990] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.024250] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.024279] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.031028] pinctrl core: initialized pinctrl subsystem
[ 0.032014] NET: Registered protocol family 16
[ 0.036039] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.036639] audit: initializing netlink subsys (disabled)
[ 0.036891] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
[ 0.038139] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.038153] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.038482] Serial: AMBA PL011 UART driver
[ 0.042368] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.060828] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-10-22 13:59, variant start
[ 0.070843] raspberrypi-firmware soc:firmware: Firmware hash is 74e754ff8947c58d2773253f77f6f68a303188f8
[ 0.126467] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.131646] vgaarb: loaded
[ 0.132112] SCSI subsystem initialized
[ 0.132319] usbcore: registered new interface driver usbfs
[ 0.132391] usbcore: registered new interface driver hub
[ 0.132524] usbcore: registered new device driver usb
[ 0.132871] usb_phy_generic phy: phy supply vcc not found, using dummy regulator
[ 0.134814] clocksource: Switched to clocksource arch_sys_counter
[ 0.842284] VFS: Disk quotas dquot_6.6.0
[ 0.842383] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.842560] FS-Cache: Loaded
[ 0.842767] CacheFiles: Loaded
[ 0.843673] simple-framebuffer 3ea50000.framebuffer: framebuffer at 0x3ea50000, 0x177000 bytes, mapped to 0x(ptrval)
[ 0.843692] simple-framebuffer 3ea50000.framebuffer: format=a8r8g8b8, mode=800x480x32, linelength=3200
[ 0.844109] Console: switching to colour frame buffer device 100x30
[ 0.846102] simple-framebuffer 3ea50000.framebuffer: fb0: simplefb registered!
[ 0.856258] thermal_sys: Registered thermal governor 'step_wise'
[ 0.856620] NET: Registered protocol family 2
[ 0.857366] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.857397] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.857465] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.857532] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.857680] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.857712] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.857965] NET: Registered protocol family 1
[ 0.858723] RPC: Registered named UNIX socket transport module.
[ 0.858737] RPC: Registered udp transport module.
[ 0.858749] RPC: Registered tcp transport module.
[ 0.858762] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.858783] PCI: CLS 0 bytes, default 64
[ 0.860844] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.863049] Initialise system trusted keyrings
[ 0.863308] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[ 0.874161] FS-Cache: Netfs 'nfs' registered for caching
[ 0.874920] NFS: Registering the id_resolver key type
[ 0.874978] Key type id_resolver registered
[ 0.874991] Key type id_legacy registered
[ 0.875014] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.876149] Key type asymmetric registered
[ 0.876163] Asymmetric key parser 'x509' registered
[ 0.876356] bounce: pool size: 64 pages
[ 0.876416] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.876642] io scheduler mq-deadline registered
[ 0.876657] io scheduler kyber registered
[ 0.880799] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 0.880823] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 0.880895] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x0603ffffff -> 0x00f8000000
[ 0.880967] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x00bfffffff -> 0x0000000000
[ 0.936962] brcm-pcie fd500000.pcie: link up, 5 GT/s x1 (SSC)
[ 0.937286] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 0.937305] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.937325] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[ 0.937384] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 0.937655] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 0.940976] PCI: bus0: Fast back to back transfers disabled
[ 0.941208] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 0.941356] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.941789] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 0.945165] PCI: bus1: Fast back to back transfers disabled
[ 0.945225] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 0.945248] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 0.945330] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.945355] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 0.945673] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[ 0.945917] pcieport 0000:00:00.0: PME: Signaling with IRQ 56
[ 0.946312] pcieport 0000:00:00.0: AER: enabled with IRQ 56
[ 0.946652] pci 0000:01:00.0: enabling device (0140 -> 0142)
[ 0.951773] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[ 0.954751] iproc-rng200 fe104000.rng: hwrng registered
[ 0.955154] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 0.955840] vc-sm: Videocore shared memory driver
[ 0.956430] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 0.968666] brd: module loaded
[ 0.981042] loop: module loaded
[ 0.982503] Loading iSCSI transport class v2.0-870.
[ 0.984512] libphy: Fixed MDIO Bus: probed
[ 0.985213] bcmgenet fd580000.ethernet: failed to get enet clock
[ 0.985232] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 0.985254] bcmgenet fd580000.ethernet: failed to get enet-wol clock
[ 0.985276] bcmgenet fd580000.ethernet: failed to get enet-eee clock
[ 0.985303] bcmgenet: Skipping UMAC reset
[ 1.004900] libphy: bcmgenet MII bus: probed
[ 1.094929] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.095965] usbcore: registered new interface driver r8152
[ 1.096043] usbcore: registered new interface driver lan78xx
[ 1.096101] usbcore: registered new interface driver smsc95xx
[ 1.096534] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.096579] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.099175] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
[ 1.100465] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 1.100482] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.100499] usb usb1: Product: xHCI Host Controller
[ 1.100515] usb usb1: Manufacturer: Linux 5.4.72-v7l+ xhci-hcd
[ 1.100529] usb usb1: SerialNumber: 0000:01:00.0
[ 1.101165] hub 1-0:1.0: USB hub found
[ 1.101263] hub 1-0:1.0: 1 port detected
[ 1.101830] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.101857] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.101881] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.102413] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[ 1.102431] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.102447] usb usb2: Product: xHCI Host Controller
[ 1.102462] usb usb2: Manufacturer: Linux 5.4.72-v7l+ xhci-hcd
[ 1.102476] usb usb2: SerialNumber: 0000:01:00.0
[ 1.103067] hub 2-0:1.0: USB hub found
[ 1.103178] hub 2-0:1.0: 4 ports detected
[ 1.104702] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.105070] dwc_otg: FIQ enabled
[ 1.105083] dwc_otg: NAK holdoff enabled
[ 1.105096] dwc_otg: FIQ split-transaction FSM enabled
[ 1.105111] Module dwc_common_port init
[ 1.105545] usbcore: registered new interface driver uas
[ 1.105647] usbcore: registered new interface driver usb-storage
[ 1.105869] mousedev: PS/2 mouse device common for all mice
[ 1.107837] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.111370] sdhci: Secure Digital Host Controller Interface driver
[ 1.111382] sdhci: Copyright(c) Pierre Ossman
[ 1.112024] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 1.112660] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.116744] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.117054] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.117250] usbcore: registered new interface driver usbhid
[ 1.117263] usbhid: USB HID core driver
[ 1.118344] vchiq: vchiq_init_state: slot_zero = (ptrval)
[ 1.120294] [vc_sm_connected_init]: start
[ 1.129524] [vc_sm_connected_init]: end - returning 0
[ 1.131511] Initializing XFRM netlink socket
[ 1.131551] NET: Registered protocol family 17
[ 1.131656] Key type dns_resolver registered
[ 1.132175] Registering SWP/SWPB emulation handler
[ 1.132485] registered taskstats version 1
[ 1.132503] Loading compiled-in X.509 certificates
[ 1.133042] Key type ._fscrypt registered
[ 1.133056] Key type .fscrypt registered
[ 1.143699] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.143775] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 29, base_baud = 0) is a PL011 rev2
[ 1.143844] printk: console [ttyAMA0] enabled
[ 1.150012] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.151029] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.151045] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.201703] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.203359] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.206114] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.209120] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.210794] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.214855] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ 1.217800] of_cfs_init
[ 1.218069] of_cfs_init: OK
[ 1.219649] Waiting for root device PARTUUID=38df017e-02...
[ 1.257053] random: fast init done
[ 1.283439] mmc1: new high speed SDIO card at address 0001
[ 1.323606] mmc0: new ultra high speed DDR50 SDHC card at address 59b4
[ 1.324528] mmcblk0: mmc0:59b4 SDU1 14.7 GiB
[ 1.326490] mmcblk0: p1 p2
[ 1.344368] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.344444] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.345871] devtmpfs: mounted
[ 1.354507] Freeing unused kernel memory: 2048K
[ 1.385122] Run /sbin/init as init process
[ 1.464914] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.647496] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.647515] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.647531] usb 1-1: Product: USB2.0 Hub
[ 1.649709] hub 1-1:1.0: USB hub found
[ 1.650027] hub 1-1:1.0: 4 ports detected
[ 1.866555] systemd[1]: System time before build time, advancing clock.
[ 1.968023] NET: Registered protocol family 10
[ 1.969367] Segment Routing with IPv6
[ 1.974923] usb 1-1.3: new full-speed USB device number 3 using xhci_hcd
[ 1.998330] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +BANNED +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 1.999118] systemd[1]: Detected architecture arm.
[ 2.066808] systemd[1]: Set hostname to <raspberrypi>.
[ 2.135149] usb 1-1.3: New USB device found, idVendor=0a12, idProduct=0001, bcdDevice=88.91
[ 2.135181] usb 1-1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2.135207] usb 1-1.3: Product: CSR8510 A10
[ 2.234893] usb 1-1.4: new full-speed USB device number 4 using xhci_hcd
[ 2.260737] uart-pl011 fe201000.serial: no DMA platform data
[ 2.381280] usb 1-1.4: New USB device found, idVendor=1b3f, idProduct=2008, bcdDevice= 1.00
[ 2.381300] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.381317] usb 1-1.4: Product: USB Audio Device
[ 2.381333] usb 1-1.4: Manufacturer: GeneralPlus
[ 2.390195] input: GeneralPlus USB Audio Device as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.3/0003:1B3F:2008.0001/input/input0
[ 2.455232] hid-generic 0003:1B3F:2008.0001: input,hidraw0: USB HID v2.01 Device [GeneralPlus USB Audio Device] on usb-0000:01:00.0-1.4/input3
[ 2.927994] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.939346] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.939742] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 2.940184] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.943289] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 2.943454] systemd[1]: Reached target Swap.
[ 2.944441] systemd[1]: Listening on Journal Audit Socket.
[ 2.945673] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.946459] systemd[1]: Listening on Syslog Socket.
[ 2.947684] systemd[1]: Created slice User and Session Slice.
[ 3.066974] i2c /dev entries driver
[ 3.597554] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.696036] systemd-journald[114]: Received request to flush runtime journal from PID 1
[ 4.359702] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.361694] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 4.361715] [vc_sm_connected_init]: start
[ 4.367987] [vc_sm_connected_init]: installed successfully
[ 4.385698] mc: Linux media interface: v0.10
[ 4.386278] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[ 4.386723] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[ 4.387534] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[ 4.387945] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[ 4.421981] videodev: Linux video capture interface: v2.00
[ 4.478117] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.480486] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.488749] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.509698] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.524085] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.542485] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 4.543097] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 4.543157] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 4.543482] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 4.544026] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 4.544441] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 4.544477] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 4.544504] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 4.544524] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 4.544544] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 4.544767] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 4.562968] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 4.563011] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 4.578574] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 4.578615] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 4.614233] input: raspberrypi-ts as /devices/platform/soc/soc:firmware/soc:firmware:touchscreen/input/input1
[ 4.892243] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 5.016719] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.051780] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 5.053122] checking generic (3ea50000 177000) vs hw (0 ffffffffffffffff)
[ 5.053139] fb0: switching to vc4drmfb from simple
[ 5.057352] Console: switching to colour dummy device 80x30
[ 5.057625] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 5.057638] [drm] No driver support for vblank timestamp query.
[ 5.057651] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
[ 5.059083] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[ 5.106271] Console: switching to colour frame buffer device 100x30
[ 5.120741] vc4-drm gpu: fb0: vc4drmfb frame buffer device
[ 5.120784] Bluetooth: Core ver 2.22
[ 5.120872] NET: Registered protocol family 31
[ 5.120886] Bluetooth: HCI device and connection manager initialized
[ 5.120911] Bluetooth: HCI socket layer initialized
[ 5.120932] Bluetooth: L2CAP socket layer initialized
[ 5.120964] Bluetooth: SCO socket layer initialized
[ 5.156029] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 5.163060] usbcore: registered new interface driver btusb
[ 5.235110] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 5.249604] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.250621] usbcore: registered new interface driver brcmfmac
[ 5.279839] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
[ 5.292065] usbcore: registered new interface driver snd-usb-audio
[ 5.520107] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.536753] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 23 2020 02:19:54 version 7.45.206 (r725000 CY) FWID 01-88ee44ea
[ 7.696933] random: crng init done
[ 7.696952] random: 7 urandom warning(s) missed due to ratelimiting
[ 8.000126] 8021q: 802.1Q VLAN Support v1.8
[ 8.384891] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 8.401981] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 8.401997] Bluetooth: BNEP filters: protocol multicast
[ 8.402027] Bluetooth: BNEP socket layer initialized
[ 8.548434] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 8.860944] Bluetooth: RFCOMM TTY layer initialized
[ 8.860974] Bluetooth: RFCOMM socket layer initialized
[ 8.861009] Bluetooth: RFCOMM ver 1.11
[ 9.066489] bcmgenet: Skipping UMAC reset
[ 9.068092] bcmgenet fd580000.ethernet: configuring instance for external RGMII
[ 9.068327] bcmgenet fd580000.ethernet eth0: Link is Down
[ 10.851189] broken atomic modeset userspace detected, disabling atomic
[ 13.969194] fuse: init (API version 7.31)
[ 14.234925] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 14.234951] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 20.453267] v3d fec00000.v3d: MMU error from client L2T (0) at 0x16c1000, pte invalid
pi@raspberrypi:~ $ dmesg | grep i2c
pi@raspberrypi:~ $ sudo nano /boot/config.txt
pi@raspberrypi:~ $ sudo reboot
login as: pi
[email protected]'s password:
Linux raspberrypi 5.4.72-v7l+ #1356 SMP Thu Oct 22 13:57:51 BST 2020 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Mon Nov 23 20:50:03 2020
SSH is enabled and the default password for the 'pi' user has not been changed.
This is a security risk - please login as the 'pi' user and type 'passwd' to set a new password.
pi@raspberrypi:~ $ dtoverlay=i2c-rtc,pcf8523
pi@raspberrypi:~ $
[ 5.665630] rtc-pcf8523 1-0068: failed to set xtal load capacitance: -121
[ 5.666320] rtc-pcf8523: probe of 1-0068 failed with error -121
[ 0.000006] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000022] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000099] bcm2835: system timer (irq = 17)
[ 0.000782] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000794] Switching to timer-based delay loop, resolution 18ns
[ 0.001030] Console: colour dummy device 80x30
[ 0.001064] printk: console [tty3] enabled
[ 0.001117] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[ 0.001138] pid_max: default: 32768 minimum: 301
[ 0.001478] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.001502] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.002764] Disabling memory control group subsystem
[ 0.003398] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.004314] Setting up static identity map for 0x200000 - 0x20003c
[ 0.004518] rcu: Hierarchical SRCU implementation.
[ 0.005194] smp: Bringing up secondary CPUs ...
[ 0.006385] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.007717] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.008985] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.009142] smp: Brought up 1 node, 4 CPUs
[ 0.009159] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.009172] CPU: All CPU(s) started in HYP mode.
[ 0.009184] CPU: Virtualization extensions available.
[ 0.010004] devtmpfs: initialized
[ 0.023987] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.024247] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.024276] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.030999] pinctrl core: initialized pinctrl subsystem
[ 0.031998] NET: Registered protocol family 16
[ 0.036049] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.036628] audit: initializing netlink subsys (disabled)
[ 0.036882] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
[ 0.038124] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.038138] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.038467] Serial: AMBA PL011 UART driver
[ 0.042394] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.060817] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-10-22 13:59, variant start
[ 0.070834] raspberrypi-firmware soc:firmware: Firmware hash is 74e754ff8947c58d2773253f77f6f68a303188f8
[ 0.126395] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.131566] vgaarb: loaded
[ 0.132030] SCSI subsystem initialized
[ 0.132234] usbcore: registered new interface driver usbfs
[ 0.132302] usbcore: registered new interface driver hub
[ 0.132423] usbcore: registered new device driver usb
[ 0.132772] usb_phy_generic phy: phy supply vcc not found, using dummy regulator
[ 0.134723] clocksource: Switched to clocksource arch_sys_counter
[ 0.841818] VFS: Disk quotas dquot_6.6.0
[ 0.841917] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.842097] FS-Cache: Loaded
[ 0.842293] CacheFiles: Loaded
[ 0.843189] simple-framebuffer 3ea50000.framebuffer: framebuffer at 0x3ea50000, 0x177000 bytes, mapped to 0x(ptrval)
[ 0.843210] simple-framebuffer 3ea50000.framebuffer: format=a8r8g8b8, mode=800x480x32, linelength=3200
[ 0.843630] Console: switching to colour frame buffer device 100x30
[ 0.845619] simple-framebuffer 3ea50000.framebuffer: fb0: simplefb registered!
[ 0.855715] thermal_sys: Registered thermal governor 'step_wise'
[ 0.856087] NET: Registered protocol family 2
[ 0.856832] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.856863] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.856932] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.857000] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.857150] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.857182] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.857445] NET: Registered protocol family 1
[ 0.858175] RPC: Registered named UNIX socket transport module.
[ 0.858189] RPC: Registered udp transport module.
[ 0.858201] RPC: Registered tcp transport module.
[ 0.858214] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.858235] PCI: CLS 0 bytes, default 64
[ 0.860294] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.862496] Initialise system trusted keyrings
[ 0.862784] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[ 0.873631] FS-Cache: Netfs 'nfs' registered for caching
[ 0.874378] NFS: Registering the id_resolver key type
[ 0.874426] Key type id_resolver registered
[ 0.874439] Key type id_legacy registered
[ 0.874463] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.875638] Key type asymmetric registered
[ 0.875652] Asymmetric key parser 'x509' registered
[ 0.875844] bounce: pool size: 64 pages
[ 0.875918] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.876147] io scheduler mq-deadline registered
[ 0.876162] io scheduler kyber registered
[ 0.880300] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 0.880323] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 0.880395] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x0603ffffff -> 0x00f8000000
[ 0.880467] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x00bfffffff -> 0x0000000000
[ 0.936845] brcm-pcie fd500000.pcie: link up, 5 GT/s x1 (SSC)
[ 0.937154] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 0.937173] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.937193] pci_bus 0000:00: root bus resource [mem 0x600000000-0x603ffffff] (bus address [0xf8000000-0xfbffffff])
[ 0.937252] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 0.937523] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 0.940877] PCI: bus0: Fast back to back transfers disabled
[ 0.941108] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 0.941255] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.941688] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 0.945089] PCI: bus1: Fast back to back transfers disabled
[ 0.945149] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 0.945172] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 0.945254] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.945279] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 0.945613] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[ 0.945846] pcieport 0000:00:00.0: PME: Signaling with IRQ 56
[ 0.946244] pcieport 0000:00:00.0: AER: enabled with IRQ 56
[ 0.946583] pci 0000:01:00.0: enabling device (0140 -> 0142)
[ 0.951678] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[ 0.954663] iproc-rng200 fe104000.rng: hwrng registered
[ 0.955066] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 0.955756] vc-sm: Videocore shared memory driver
[ 0.956345] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 0.968555] brd: module loaded
[ 0.980907] loop: module loaded
[ 0.982385] Loading iSCSI transport class v2.0-870.
[ 0.984365] libphy: Fixed MDIO Bus: probed
[ 0.985066] bcmgenet fd580000.ethernet: failed to get enet clock
[ 0.985086] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 0.985109] bcmgenet fd580000.ethernet: failed to get enet-wol clock
[ 0.985131] bcmgenet fd580000.ethernet: failed to get enet-eee clock
[ 0.985159] bcmgenet: Skipping UMAC reset
[ 1.004814] libphy: bcmgenet MII bus: probed
[ 1.094835] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.095871] usbcore: registered new interface driver r8152
[ 1.095934] usbcore: registered new interface driver lan78xx
[ 1.095991] usbcore: registered new interface driver smsc95xx
[ 1.096422] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.096469] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.099082] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000001000000890
[ 1.100386] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 1.100405] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.100421] usb usb1: Product: xHCI Host Controller
[ 1.100436] usb usb1: Manufacturer: Linux 5.4.72-v7l+ xhci-hcd
[ 1.100451] usb usb1: SerialNumber: 0000:01:00.0
[ 1.101069] hub 1-0:1.0: USB hub found
[ 1.101166] hub 1-0:1.0: 1 port detected
[ 1.101731] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.101757] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.101781] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.102313] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[ 1.102331] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.102346] usb usb2: Product: xHCI Host Controller
[ 1.102362] usb usb2: Manufacturer: Linux 5.4.72-v7l+ xhci-hcd
[ 1.102377] usb usb2: SerialNumber: 0000:01:00.0
[ 1.102970] hub 2-0:1.0: USB hub found
[ 1.103057] hub 2-0:1.0: 4 ports detected
[ 1.104580] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.104950] dwc_otg: FIQ enabled
[ 1.104963] dwc_otg: NAK holdoff enabled
[ 1.104975] dwc_otg: FIQ split-transaction FSM enabled
[ 1.104991] Module dwc_common_port init
[ 1.105430] usbcore: registered new interface driver uas
[ 1.105546] usbcore: registered new interface driver usb-storage
[ 1.105739] mousedev: PS/2 mouse device common for all mice
[ 1.107689] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.111239] sdhci: Secure Digital Host Controller Interface driver
[ 1.111252] sdhci: Copyright(c) Pierre Ossman
[ 1.111891] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 1.112507] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.116414] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.116725] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.116925] usbcore: registered new interface driver usbhid
[ 1.116938] usbhid: USB HID core driver
[ 1.118022] vchiq: vchiq_init_state: slot_zero = (ptrval)
[ 1.119969] [vc_sm_connected_init]: start
[ 1.129190] [vc_sm_connected_init]: end - returning 0
[ 1.131151] Initializing XFRM netlink socket
[ 1.131193] NET: Registered protocol family 17
[ 1.131297] Key type dns_resolver registered
[ 1.131817] Registering SWP/SWPB emulation handler
[ 1.132127] registered taskstats version 1
[ 1.132146] Loading compiled-in X.509 certificates
[ 1.132710] Key type ._fscrypt registered
[ 1.132724] Key type .fscrypt registered
[ 1.143344] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.143419] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 29, base_baud = 0) is a PL011 rev2
[ 1.143486] printk: console [ttyAMA0] enabled
[ 1.149648] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.150662] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.150678] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.202035] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.203693] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.206372] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.209371] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.211040] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.218751] mmc0: SDHCI controller on fe340000.emmc2 [fe340000.emmc2] using ADMA
[ 1.221930] of_cfs_init
[ 1.222075] of_cfs_init: OK
[ 1.223656] Waiting for root device PARTUUID=38df017e-02...
[ 1.260982] random: fast init done
[ 1.283365] mmc1: new high speed SDIO card at address 0001
[ 1.328356] mmc0: new ultra high speed DDR50 SDHC card at address 59b4
[ 1.329306] mmcblk0: mmc0:59b4 SDU1 14.7 GiB
[ 1.331136] mmcblk0: p1 p2
[ 1.343913] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.343987] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.345418] devtmpfs: mounted
[ 1.354177] Freeing unused kernel memory: 2048K
[ 1.385036] Run /sbin/init as init process
[ 1.464798] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.647383] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.647402] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.647419] usb 1-1: Product: USB2.0 Hub
[ 1.649302] hub 1-1:1.0: USB hub found
[ 1.649737] hub 1-1:1.0: 4 ports detected
[ 1.867259] systemd[1]: System time before build time, advancing clock.
[ 1.968775] NET: Registered protocol family 10
[ 1.970154] Segment Routing with IPv6
[ 1.974784] usb 1-1.3: new full-speed USB device number 3 using xhci_hcd
[ 1.999397] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +BANNED +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.000173] systemd[1]: Detected architecture arm.
[ 2.049222] systemd[1]: Set hostname to <raspberrypi>.
[ 2.134464] usb 1-1.3: New USB device found, idVendor=0a12, idProduct=0001, bcdDevice=88.91
[ 2.134488] usb 1-1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2.134504] usb 1-1.3: Product: CSR8510 A10
[ 2.234834] usb 1-1.4: new full-speed USB device number 4 using xhci_hcd
[ 2.241175] uart-pl011 fe201000.serial: no DMA platform data
[ 2.379730] usb 1-1.4: New USB device found, idVendor=1b3f, idProduct=2008, bcdDevice= 1.00
[ 2.379750] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.379768] usb 1-1.4: Product: USB Audio Device
[ 2.379784] usb 1-1.4: Manufacturer: GeneralPlus
[ 2.390592] input: GeneralPlus USB Audio Device as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.3/0003:1B3F:2008.0001/input/input0
[ 2.455213] hid-generic 0003:1B3F:2008.0001: input,hidraw0: USB HID v2.01 Device [GeneralPlus USB Audio Device] on usb-0000:01:00.0-1.4/input3
[ 2.912455] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.923899] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.924831] systemd[1]: Listening on Journal Socket.
[ 2.925261] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.925838] systemd[1]: Listening on Journal Socket (/dev/log).
[ 2.933507] systemd[1]: Mounting Kernel Debug File System...
[ 2.934517] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 2.936359] systemd[1]: Created slice User and Session Slice.
[ 2.942583] systemd[1]: Mounting POSIX Message Queue File System...
[ 2.943940] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 3.125934] i2c /dev entries driver
[ 3.562973] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.671849] systemd-journald[111]: Received request to flush runtime journal from PID 1
[ 4.318961] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[ 4.356576] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[ 4.357074] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[ 4.357861] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[ 4.397414] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.399910] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 4.399933] [vc_sm_connected_init]: start
[ 4.404131] [vc_sm_connected_init]: installed successfully
[ 4.421191] mc: Linux media interface: v0.10
[ 4.506916] input: raspberrypi-ts as /devices/platform/soc/soc:firmware/soc:firmware:touchscreen/input/input1
[ 4.545385] videodev: Linux video capture interface: v2.00
[ 4.628626] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.628949] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.642083] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.645917] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.651442] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.670425] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 4.670469] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 4.677608] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 4.678153] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 4.678589] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 4.678908] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 4.678935] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 4.678958] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 4.678979] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 4.679000] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 4.679188] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 4.689074] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 4.689120] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 4.698337] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 4.698380] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 4.747446] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 4.822925] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 4.833245] Bluetooth: Core ver 2.22
[ 4.833318] NET: Registered protocol family 31
[ 4.833332] Bluetooth: HCI device and connection manager initialized
[ 4.833357] Bluetooth: HCI socket layer initialized
[ 4.833378] Bluetooth: L2CAP socket layer initialized
[ 4.833412] Bluetooth: SCO socket layer initialized
[ 4.891704] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 4.896936] usbcore: registered new interface driver btusb
[ 4.944922] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 4.955401] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 4.955869] usbcore: registered new interface driver brcmfmac
[ 4.985620] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 4.985643] checking generic (3ea50000 177000) vs hw (0 ffffffffffffffff)
[ 4.985659] fb0: switching to vc4drmfb from simple
[ 4.988391] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.txt failed with error -2
[ 5.004186] Console: switching to colour dummy device 80x30
[ 5.005403] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 5.005419] [drm] No driver support for vblank timestamp query.
[ 5.005432] [drm] Setting vblank_disable_immediate to false because get_vblank_timestamp == NULL
[ 5.006627] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[ 5.028033] Console: switching to colour frame buffer device 100x30
[ 5.042261] vc4-drm gpu: fb0: vc4drmfb frame buffer device
[ 5.247476] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.251617] usbcore: registered new interface driver snd-usb-audio
[ 5.266444] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 23 2020 02:19:54 version 7.45.206 (r725000 CY) FWID 01-88ee44ea
[ 7.507763] random: crng init done
[ 7.507789] random: 7 urandom warning(s) missed due to ratelimiting
[ 7.906765] 8021q: 802.1Q VLAN Support v1.8
[ 8.307141] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 8.335001] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 8.335016] Bluetooth: BNEP filters: protocol multicast
[ 8.335044] Bluetooth: BNEP socket layer initialized
[ 8.513749] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 8.747585] Bluetooth: RFCOMM TTY layer initialized
[ 8.747615] Bluetooth: RFCOMM socket layer initialized
[ 8.747650] Bluetooth: RFCOMM ver 1.11
[ 8.944817] bcmgenet: Skipping UMAC reset
[ 8.946536] bcmgenet fd580000.ethernet: configuring instance for external RGMII
[ 8.948213] bcmgenet fd580000.ethernet eth0: Link is Down
[ 10.800684] broken atomic modeset userspace detected, disabling atomic
[ 13.993566] fuse: init (API version 7.31)
[ 14.154930] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 14.154959] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 20.502701] v3d fec00000.v3d: MMU error from client L2T (0) at 0x1d21000, pte invalid
pi@raspberrypi:~ $
login as: pi
pi@raspberrypi:~ $
pi@raspberrypi:~ $
- FullRestoreand3vout.txt
- file of the above output.
- (51.35 KiB) Downloaded 48 times
Attaching to 5V would not have damaged the PCF. You risk damaging the Pi's pin though, since VCC sets the voltage level.
Do you have another I2C device and/or another Pi? (or even something like an Arduino board)
- Jizobizo
sorry, I have a pi 3b+ and a 4 4gb and the one RTC.
Ah, I think I missed this. Doing the same on both. Hmmm. Not sure. It should show up with the I2C scan. Even without a battery installed.This is on both a rpi 3b+ and a 4 4gb:
Let's replace it and see what happens. Send an email to [email protected] with a link to this thread and your order number and they can send you a replacement PCF8523 RTC.
- Jizobizo
Thank you very much for your help.
