MakeCode doe CPB
Microsoft's MakeCode platform for easy blocks-style programming
gallaugher
MakeCode doe CPB
Post by gallaugher »
I realize that MakeCode for the CircuitPlayground Bluefruit is still in beta. I’m wondering if the simulator allows for the changing of temperatures, light, or sound, or switching the slide switch on the CPB, or is this something you can’t use the simulator for and need to rely on loading and running code on a physical device. Thanks. Also - what’s the large AB circle on the simulator. It can be selected and gets a yellow outline but I’m not sure what this does.
blnkjns
Re: MakeCode doe CPB
Post by blnkjns »
I see a microphone component on that spot. And it gets a yellow line if I drag the block "on loud sound".
johnpark
Post by johnpark »
The AB button should be the simulator's way of allowing you to press the A and B buttons at the same time.
Return to “MakeCode”
