ADABOX019 MacroPad I2C diagram has wrong pinout.
SpaceCoaster
Post by SpaceCoaster »
The diagram of the pinouts for the I2C connector on the MacroPad is wrong!
https://learn.adafruit.com/assets/103286
The pinout order is the same as the FunHouse, from the top SCL/SDA/3.3V/GND.
adafruit2
Re: ADABOX019 MacroPad I2C diagram has wrong pinout.
Post by adafruit2 »
you can use the wire colors to identify pins
SpaceCoaster
Thanks, I was making some cables and I used the MacroPad pin out diagram as my model. It is wrong!
I reported it as a bug.
kattni
Post by kattni »
Apologies for the inconvenience. I replied on GitHub. The issue was with the Fritzing object which is used for the basis of the PrettyPins images. I have updated both.
SpaceCoaster
No inconvenience at all. Your documentation is wonderful and very much appreciated! My apologies for spamming it to several places.
Return to “AdaBox! Show us what you made!”
