Macropad Speaker Shutdown
- kirksan
I’m not sure if this is the best forum for this but I’m hoping someone can point me in the right direction. I’ve started having errors with my Macropad, when I load code I get an error “Speaker Shutdown”. Code that ran correctly in the past, usually won’t run now. It’s not consistent, every once in a while I can get code to run but then that error comes back. I’m not using any sounds or tones.
- adafruit_support_carter
Re: Macropad Speaker Shutdown
Can you link to the program you are running? Is it from a guide?
