Hi all...! I'm trying to run this nifty program from the learning center:
https://learn.adafruit.com/clue-sensor- ... cuitpython
Followed instructions and all went well, downloaded spec'd files, created Clue as USB drive, uploaded circuit python 6.30 and libraries, transferred individual files, everything working as expected. But then on startup, screen shows horizontal wavy lines for a split-second, and goes to error message:
Line 41 calls plotter, but message says it can't find plotter, even though plotter.py is in the same directory. ??
So is there really a bug in the code at line 41, or have I repeatedly done something wrong in my setup?
Anybody help out a newbie here?
TIA
Steve
setting up CLUE Sensor Plotter in CircuitPython
- SGEDESIGNS
- dastels
Re: setting up CLUE Sensor Plotter in CircuitPython
Please post your code (in the message, in a code block is best) as well as the contents of CIRCUITPY (screenshot is fine).
- SGEDESIGNS
Hey Dave, thanks for the quick response!
Here's the code:
# clue-plotter v1.14
# Sensor and input plotter for Adafruit CLUE in CircuitPython
# This plots the sensors and three of the analogue inputs on
# the LCD display either with scrolling or wrap mode which
# approximates a slow timebase oscilloscope, left button selects
# next source or with long press changes palette or longer press
# turns on output for Mu plotting, right button changes plot style
# Tested with an Adafruit CLUE (Alpha) and CircuitPython and 5.0.0
# copy this file to CLUE board as code.py
# needs companion plot_sensor.py and plotter.py files
# MIT License
# Copyright (c) 2020 Kevin J. Walters
# Permission is hereby granted, free of charge, to any person obtaining a copy
# of this software and associated documentation files (the "Software"), to deal
# in the Software without restriction, including without limitation the rights
# to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
# copies of the Software, and to permit persons to whom the Software is
# furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in all
# copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
# AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
# OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
# SOFTWARE.
import time
import gc
import board
from plotter import Plotter
from plot_source import PlotSource, TemperaturePlotSource, PressurePlotSource, \
HumidityPlotSource, ColorPlotSource, ProximityPlotSource, \
IlluminatedColorPlotSource, VolumePlotSource, \
AccelerometerPlotSource, GyroPlotSource, \
MagnetometerPlotSource, PinPlotSource
from adafruit_clue import clue
debug = 1
# A list of all the data sources for plotting
sources = [TemperaturePlotSource(clue, mode="Celsius"),
TemperaturePlotSource(clue, mode="Fahrenheit"),
PressurePlotSource(clue, mode="Metric"),
PressurePlotSource(clue, mode="Imperial"),
HumidityPlotSource(clue),
ColorPlotSource(clue),
ProximityPlotSource(clue),
IlluminatedColorPlotSource(clue, mode="Red"),
IlluminatedColorPlotSource(clue, mode="Green"),
IlluminatedColorPlotSource(clue, mode="Blue"),
IlluminatedColorPlotSource(clue, mode="Clear"),
VolumePlotSource(clue),
AccelerometerPlotSource(clue),
GyroPlotSource(clue),
MagnetometerPlotSource(clue),
PinPlotSource([board.P0, board.P1, board.P2])
# The first source to select when plotting starts
current_source_idx = 0
# The various plotting styles - scroll is currently a jump scroll
stylemodes = (("lines", "scroll"), # draws lines between points
("lines", "wrap"),
("dots", "scroll"), # just points - slightly quicker
("dots", "wrap")
current_sm_idx = 0
def d_print(level, *args, **kwargs):
"""A simple conditional print for debugging based on global debug level."""
if not isinstance(level, int):
elif debug >= level:
print(*args, **kwargs)
def select_colors(plttr, src, def_palette):
"""Choose the colours based on the particular PlotSource
or forcing use of default palette."""
# otherwise use defaults
channel_colidx = []
palette = plttr.get_colors()
colors = PlotSource.DEFAULT_COLORS if def_palette else src.colors()
for col in colors:
try:
channel_colidx.append(palette.index(col))
except ValueError:
channel_colidx.append(PlotSource.DEFAULT_COLORS.index(col))
return channel_colidx
def ready_plot_source(plttr, srcs, def_palette, index=0):
"""Select the plot source by index from srcs list and then setup the
plot parameters by retrieving meta-data from the PlotSource object."""
src = srcs[index]
# Put the description of the source on screen at the top
source_name = str(src)
d_print(1, "Selecting source:", source_name)
plttr.clear_all()
plttr.title = source_name
plttr.y_axis_lab = src.units()
# The range on graph will start at this value
plttr.y_range = (src.initial_min(), src.initial_max())
plttr.y_min_range = src.range_min()
# Sensor/data source is expected to produce data between these values
plttr.y_full_range = (src.min(), src.max())
channels_from_src = src.values()
plttr.channels = channels_from_src # Can be between 1 and 3
plttr.channel_colidx = select_colors(plttr, src, def_palette)
src.start()
return (src, channels_from_src)
def wait_release(func, menu):
"""Calls func repeatedly waiting for it to return a false value
and goes through menu list as time passes.
The menu is a list of menu entries where each entry is a
two element list of time passed in seconds and text to display
for that period.
The entries must be in ascending time order."""
start_t_ns = time.monotonic_ns()
menu_option = None
selected = False
for menu_option, menu_entry in enumerate(menu):
menu_time_ns = start_t_ns + int(menu_entry[0] * 1e9)
menu_text = menu_entry[1]
if menu_text:
plotter.info = menu_text
while time.monotonic_ns() < menu_time_ns:
if not func():
selected = True
break
if menu_text:
plotter.info = ""
if selected:
break
return (menu_option, (time.monotonic_ns() - start_t_ns) * 1e-9)
def popup_text(plttr, text, duration=1.0):
"""Place some text on the screen using info property of Plotter object
for duration seconds."""
plttr.info = text
time.sleep(duration)
plttr.info = None
mu_plotter_output = False
range_lock = False
initial_title = "CLUE Plotter"
# displayio has some static limits on text - pre-calculate the maximum
# length of all of the different PlotSource objects
max_title_len = max(len(initial_title), max([len(str(so)) for so in sources]))
plotter = Plotter(board.DISPLAY,
style=stylemodes[current_sm_idx][0],
mode=stylemodes[current_sm_idx][1],
title=initial_title,
max_title_len=max_title_len,
mu_output=mu_plotter_output,
debug=debug)
# If set to true this forces use of colour blind ness friendly colours
use_def_pal = False
clue.pixel[0] = clue.BLACK # turn off the NeoPixel on the back of CLUE board
plotter.display_on()
# Using left and right here in case the CLUE is cased hiding A/B labels
popup_text(plotter,
"\n".join(["Button Guide",
"Left: next source",
" 2secs: palette",
" 4s: Mu plot",
" 6s: range lock",
"Right: style change"]), duration=10)
count = 0
while True:
# Set the source and start items
(source, channels) = ready_plot_source(plotter, sources,
use_def_pal,
current_source_idx)
while True:
# Read data from sensor or voltage from pad
all_data = source.data()
# Check for left (A) and right (B) buttons
if clue.button_a:
# Wait for button release with time-based menu
opt, _ = wait_release(lambda: clue.button_a,
[(2, "Next\nsource"),
(4,
("Source" if use_def_pal else "Default")
+ "\npalette"),
(6,
"Mu output "
+ ("off" if mu_plotter_output else "on")),
(8,
"Range lock\n" + ("off" if range_lock else "on"))
if opt == 0: # change plot source
current_source_idx = (current_source_idx + 1) % len(sources)
break # to leave inner while and select the new source
elif opt == 1: # toggle palette
use_def_pal = not use_def_pal
plotter.channel_colidx = select_colors(plotter, source,
use_def_pal)
elif opt == 2: # toggle Mu output
mu_plotter_output = not mu_plotter_output
plotter.mu_output = mu_plotter_output
else: # toggle range lock
range_lock = not range_lock
plotter.y_range_lock = range_lock
if clue.button_b: # change plot style and mode
current_sm_idx = (current_sm_idx + 1) % len(stylemodes)
(new_style, new_mode) = stylemodes[current_sm_idx]
wait_release(lambda: clue.button_b,
[(2, new_style + "\n" + new_mode)])
d_print(1, "Graph change", new_style, new_mode)
plotter.change_stylemode(new_style, new_mode)
# Display it
if channels == 1:
plotter.data_add((all_data,))
else:
plotter.data_add(all_data)
# An occasional print of free heap
if debug >=3 and count % 15 == 0:
gc.collect() # must collect() first to measure free memory
print("Free memory:", gc.mem_free())
count += 1
source.stop()
plotter.display_off()
Screenshot of circuitpy attached. I have one of the lib contents if you need it.
One thing I noticed is the error message also says that my code had two extensions, and I think (?) I understand now.
I remember using Notepad along the way, as an intermediary I think, copying the code from onscreen to the code.py file...?
Can I just rename and ditch the *.txt extension? Or better a fresh start?
Again, thx...getting this running is a major first step in the project. I think your audience will find the project interesting...check out polyopticon.com.
We're almost ready to release images into the wild.
I have another Adafruit display to configure (the 2.4" touch TFT with a bluetooth feather); starting very soon, and I'll see how that goes. :)
The learning center stuff is terrific.
Steve SGEDESIGNS
Here's the code:
# MIT License
# SOFTWARE.
import time
import gc
import board
debug = 1
("lines", "wrap"),
("dots", "wrap")
current_sm_idx = 0
channel_colidx = []
for col in colors:
try:
except ValueError:
src = srcs[index]
plttr.clear_all()
src.start()
for that period.
menu_option = None
selected = False
if menu_text:
if not func():
selected = True
break
if menu_text:
plotter.info = ""
if selected:
break
plttr.info = text
plttr.info = None
range_lock = False
debug=debug)
use_def_pal = False
popup_text(plotter,
" 2secs: palette",
" 4s: Mu plot",
" 6s: range lock",
count = 0
while True:
use_def_pal,
current_source_idx)
while True:
if clue.button_a:
(4,
+ "\npalette"),
(6,
"Mu output "
(8,
use_def_pal)
# Display it
if channels == 1:
else:
count += 1
source.stop()
Steve SGEDESIGNS
- circuitpy-01.jpg (63.99 KiB) Viewed 2139 times
- kevinjwalters
This is a new one for me but I think the problem can be seen in the first screen shot with the mention of "code.py.txt" - the file extension (a feature from CP/M via 86-DOS and MS-DOS) is actually .txt. This is also hinted at by Windows showing the files with an icon (ultimately from Xerox) and the WARNING message you spotted.
I knew CircuitPython looked for code.py and main.py but it's surprising it will execute text files. I'd imagine this is a convenience to help users with download methods where the file ends up with the extra incorrect file extension but it backfires when you have additional library files with the same superfluous extension. Here's the current (26-Sep-2021) interpreter code (main.c) confirming it can look for other names:
If you adjust all of the files from .py.txt to ,py it should work. In Windows Explorer this can be accomplished by clicking on View and ticking the checkbox for File name extensions. Right click on each file for Rename will then let you remove the troublesome .txt. Or use ren on command line.
if (safe_mode == NO_SAFE_MODE) {
static const char * const supported_filenames[] = STRING_LIST(
"code.txt", "code.py", "main.py", "main.txt");
#if CIRCUITPY_FULL_BUILD
static const char * const double_extension_filenames[] = STRING_LIST(
"code.txt.py", "code.py.txt", "code.txt.txt","code.py.py",
"main.txt.py", "main.py.txt", "main.txt.txt","main.py.py");
#endif
- SGEDESIGNS
Thx Kevin. Haven't been back to that part of the project in a few days, will try this. I often use Notepad as a catchall for copying or downloading formatted stuff, since it strips the formatting, but here, as an intermediary in my file transfer, it gotcha'd me. Will let you know.
SG
SG
