Defective Multimeter
- fro13802
Defective digital multimeter, product ID 5139, order ID 2676054-5436118528 received 10/14/2021, order date 10/10/2021. Turned on unit to verify functions. Unit shut down after a few hours (no power - no display). Fuses ok and 1 slightly low battery(( 2) 3.7V li-ions #18650(). Does not run on USB power and used different adapters (2 amp output max). No functions were ever tested. Unit was left on workbench after clock set.
- adafruit_support_carter
Re: Defective Multimeter
Can you provide more information on the USB power being used. Can you post a photo of the info sticker label on the USB power adapter?
- fro13802
Here is the image you requested.
- 20211019_194817.jpg (34.41 KiB) Viewed 866 times
- adafruit2
weird. i mean there's not a lot going on with it - email support@adafruit for a new multimeter
