Can't get ESP32 Huzzah to Wippersnapper (can't load binary)
- Blueshark
1st time I loaded the Wippersnapper firmware to ESP32 Huzzah ok, but no show on Adafruit IO Wippersnapper page, tried again no show again, tried 3rd time now get error not able to install binary...
- Screenshot (2).png (26.06 KiB) Viewed 273 times
- ksprayberry
Re: Can't get ESP32 Huzzah to Wippersnapper (can't load bina
I just finished loading mine last night and I had the same problem. What worked for me was that I loaded a program from the Arduino IDE ...maybe a Blink program or something simple and once I did that, I went back to Chrome and connected it and it connected right away, I put in my credentials and loaded the wippersnapper and it loaded without a hitch. I think the first go around I hit the reset button or it didn't take or something and then it seemed to just not work after that. Reloading the arduino program to the board seemed to do the trick.
- brubell
- Learn User Page
I could not replicate this on my end. Could you please provide me with the following information:1st time I loaded the Wippersnapper firmware to ESP32 Huzzah ok, but no show on Adafruit IO Wippersnapper page, tried again no show again, tried 3rd time now get error not able to install binary...
What browser are you using?
Which browser version are you using?
What operating system and version are you using?
- Blueshark
Note: Because Wippersnapper is using Beta Chrome extensions that affect all users of the Chrome Browser Security, I'm using an old PC to experiment on the Wippersnapper platform.
The Old PC is an Intel Centrino Dual Core 1ghz - 4 gb ram - Laptop HP.... Clean install only has Arduino IDE - Chrome installed no other complicated software installed.
Using Google Chrome Browser; followed Wippersnapper tutorial to enable experimental extensions
Currently I'm not in my home; out in a mini-vacation from home - Halloween weekend with family so giving you the exact Chrome Browser Version is not possible right now... but its current...
OS version.... is Windows 10 Pro, 21H1 - because of Clean install Windows has not been registered yet but I keep Windows updated as much as possible; I dont think the Windows update's are an issue but good to know about the computer state it is in right now.
For now on my end as soon as I get home I'll load an Arduino sketch to maybe reset the ESP32 Huzzah and then try again.
Thank You again for your support.
- Blueshark
I got it working!!!
as ksprayberry said...
I just uploaded the Blinky code from the Arduino IDE example, then went back to the Wippersnapper program re-uploaded the code; (I noticed that the ESP32 Huzzah doesn't like the 5GHz antenna on my router so I used the "GUEST" antenna and it connected)
Now I can experiment with the Wippersnapper platform!!
- Screenshot (5).png (34.64 KiB) Viewed 246 times
- brubell
- Learn User Page
Glad you got it working! I haven't seen a user attempt to connect to a 5GHz network before, the ESP32 only supports 2.4GHz networks. I'll make a note about this on the guide for the next person who encounters this issue.
