Cannot use CLUE example code - Failed to find BMP280?
clpie
Post by clpie »
Hi there,
I am just getting started and I am having a problem running the example code... I receive this error message:
code.py output:
  File "code.py", line 1, in <module>
  File "adafruit_clue.py", line 930, in <module>
  File "adafruit_clue.py", line 233, in __init__
  File "adafruit_bmp280.py", line 443, in __init__
  File "adafruit_bmp280.py", line 131, in __init__
RuntimeError: Failed to find BMP280! Chip ID 0x0
When this line of code is executed:
from adafruit_clue import clue
Which means I cannot get the examples to work.
boot_out.txt:
Adafruit CircuitPython 7.0.0 on 2021-09-20; Adafruit CLUE nRF52840 Express with nRF52840
Board ID:clue_nrf52840_express
I'm using the latest libraries and bundle:
adafruit-circuitpython-clue_nrf52840_express-en_GB-7.0.0.uf2
adafruit-circuitpython-bundle-7.x-mpy-20211101.zip
Does anyone know what might be happening here?
Thank you :)
clpie
Re: Cannot use CLUE example code - Failed to find BMP280?
Post by clpie »
OK, I have discovered this only happens when I connect a DPS310 Pressure Sensor via Stemma QT....
It is somehow interfering with the onboard pressure sensor?
clpie
Post by clpie »
Also, with an external temp/humidity sensor (SHT31) connected the example for temperature and humidity doesn't work:
  File "code.py", line 27, in <module>
  File "adafruit_clue.py", line 532, in humidity
  File "adafruit_sht31d.py", line 376, in relative_humidity
  File "adafruit_sht31d.py", line 259, in _read
  File "adafruit_sht31d.py", line 240, in _data
  File "adafruit_sht31d.py", line 140, in _unpack
RuntimeError: CRC mismatch
clpie
Post by clpie »
I can run examples fine, I am just now wondering how to use external sensors:
viewtopic.php?f=65&t=184789
thank you :)
adafruit_support_carter
You are running into an I2C address conflict. The BMP280 on the CLUE uses address 0x77. That is the same default address for the DPS310. You can change the address of the DPS310 to its alternate 0x76 address by soldering close the jumper on the back:
You will then need to specify that alternate address when setting up the DPS310 in your code:
dps310 = adafruit_dps310.DPS310(i2c, address=0x76)
Return to “CLUE Board”
