Send/Receive data from Linux
clpie
Post by clpie »
Hi there,
I was just wondering what the best method might be to have bi-directional communication with a linux machine, perhaps by serial console?
I was able to connect node.js to the CLUE via serial port and get console output from CLUE, but how do I then send data back to the CLUE? I'd like to have code running on the CLUE that can receive commands or info from a Linux computer via USB.... - is there a way to receive serial data in the circuit python code?
Thank you :D
adafruit_support_carter
Re: Send/Receive data from Linux
Take a look at the approach suggested here:
https://learn.adafruit.com/customizing- ... -3096573-5
Basically a secondary serial path you could use for any arbitrary back and forth.
clpie
Post by clpie »
Thank you -
Do you know if there are any circuit python code examples or libraries for sending/receiving arbitrary data over serial port? I couldn't find any on that page or searching around....
How might I send/receive data in code.py over the additional serial port?
Return to “CLUE Board”
