D-Ring not fitting tripod mount
Hand tools, soldering irons, scopes, multimeters. Talk about em HERE!
n3fih
Post by n3fih »
I purchased the parts recommended for the Raspberry Pi Camera tripod, and I'm having a problem. The D-ring screw (2629) doesn't fit in the tripod base. Have you encountered this problem before? Is there any chance the parts I received were a larger size than required?
adafruit_support_carter
Re: D-Ring not fitting tripod mount
What is the tripod base you are using? The PID 2629 should be a 1/4-20 thread, which is what most camera hardware uses.
Return to “Tools Tools Tools”
