Coding Blocks for Touch Sensors
- allyrwebb
Is there any way to create a coding block that involves input from 2 touch sensors at once? For example, something happens when touch sensors A2 and A3 are activated simultaneously?
- blnkjns
Re: Coding Blocks for Touch Sensors
Throw two of those blocks in a blue logic AND block.
- allyrwebb
Ok, thanks so much for the suggestion. I set the block up with "if touch A2 is pressed and touch A3 is pressed, then..." (all the outputs I wanted to see happen), but the whole block is still all greyed out. Any idea why it won't work?
- Adafruit Screenshot.png (30 KiB) Viewed 664 times
- blnkjns
Because it is out of context? There is no start block. Put it in a loop-forever block for example.
