Internet clock 1st project....HELP
For RTC breakouts, etc., use the Other Products from Adafruit forum
adafruit_support_carter
Re: Internet clock 1st project....HELP
Weird. Also not sure what was happening. But at least it seems to be working now. You may run into other issues as you proceed. When this happens, the "traceback" that gets printed is your friend. Although it can be a bit of a wall of text when first encountering it:
File "code.py", line 49, in <module>
File "adafruit_display_text/label.py", line 86, in __init__
File "adafruit_display_text/__init__.py", line 240, in __init__
File "adafruit_display_text/__init__.py", line 261, in _get_ascent_descent
File "adafruit_bitmap_font/bdf.py", line 75, in ascent
OSError: [Errno 22] Invalid argument
For the above example, line 49 in your code.py would be the first place to look. The actual error is on line 75 in adafruit_bitmap_font/bdf.py, but it could be that something was done wrong in code.py to cause this.
Ju5tAN00b2000
Post by Ju5tAN00b2000 »
Onto date and weather.
Can the date be pulled with the time or does your server just give the time? I think it has to be coded in as a seperate entity like weather?
Where can I pull the weather from? In the form of current weather icon and outside temperature?
Any guides or pointers on how to code them in?
There's a weather project here that might be a useful reference:
https://learn.adafruit.com/weather-display-matrix
Ju5tAN00b2000
Ive figured out where ive been having trouble.
I decided to try out the moon clock. Downloaded the project files. No "lib"s included so I used the library bundle on this page:
https://learn.adafruit.com/adafruit-mat ... thon-setup
goes to
https://circuitpython.org/libraries
It did NOT work.
The matrix clock files have "lib"s included. I used them instead and it worked. These clocks do not work off the latest "libs" bundles.
I tried version 6 and 7.
Return to “Clock Kits (discontinued)”
