blitFrameBuffer hangs
dstieglitz
Post by dstieglitz »
Hi there:
I am trying to use the Arcada frame buffer for double buffering on my Clue. Below is a sample program that shows the issue I'm having. The blitFrameBuffer method seems to hang on a second call after successfully drawing to the screen? Maybe it's something else. I based this code on the examples and the documentation, can anyone shed some light on what's going on here (or reproduce this)?
Arduino 1.8.16
Arcada 2.5.2
#include <Adafruit_Arcada.h>
Adafruit_Arcada arcada;
uint16_t *framebuffer;
#define SCREEN_W 240
#define SCREEN_H 240
#define DISP_TOP 30
  while (!Serial);
  Serial.begin(115200);
  Serial.println("clue_blit_test");
  if (!arcada.arcadaBegin()) {
    Serial.print("Failed to begin");
    while (1);
  delay(200);
  Serial.println("displayBegin()...");
  arcada.displayBegin();
  Serial.println("createFrameBuffer(240,240)...");
  if (! arcada.createFrameBuffer(SCREEN_W, SCREEN_H)) {
    Serial.println("Failed to allocate framebuffer");
    while (1);
  framebuffer = arcada.getFrameBuffer();
  Serial.println((int)framebuffer);
  arcada.setBacklight(255);
  delay(200);
  draw_loading_screen("Loading...", arcada.getCanvas());
  if (!arcada.blitFrameBuffer(0, 0, false, true)) {
    Serial.println("Could not blit frame buffer for some reason");
  delay(200);
  Serial.println("done setting up");
void draw_loading_screen(String text, GFXcanvas16 *_canvas) {
  Serial.println("draw_loading_screen");
  _canvas->fillScreen(ARCADA_BLACK);
  _canvas->setCursor(0, DISP_TOP);
  _canvas->setTextSize(2);
  _canvas->setTextColor(ARCADA_RED, ARCADA_BLACK);
  _canvas->print(text);
  int i = 0;
  while (1) {
    draw_loading_screen("Loading " + i, arcada.getCanvas());
    delay(1000);
    i++;
dstieglitz
Re: blitFrameBuffer hangs
FWIW this seems to be happening with the latest examples shipped for Arduino, e.g., https://github.com/adafruit/Adafruit_Ar ... lotter.ino
I'm trying to figure out if this is a "my environment" issue or a known issue with the latest libraries... if anyone can reproduce (or not) please lmk.
jimsbugs
Post by jimsbugs »
Yes, this is broken for me, too. Digging into it, there appears to be a bug in the Adafruit support for NRF52 boards in the SPI code. In version 1.2.0, line 211 of the file:
~/.arduino15/packages/adafruit/hardware/nrf52/1.2.0/libraries/SPI/SPI.cpp
is:
    const size_t xfer_len = min((uint16_t) count, UINT16_MAX);
Changing it to:
    const size_t xfer_len = min(count, UINT16_MAX);
allows blits to work properly on the CLUE. Hopefully that is sufficient to get you going.
dstieglitz
Excellent find, this fixes the problem for me -- thank you @jimsbugs.
dstieglitz
Return to “CLUE Board”
