Hi All
I have a strange issue that I am not able to solve.
I currently use a feather M4 express to talk to a SIM868 modem. The base for the project is the MQTT Fona example from Adafruit.
The idea is to use the GPS functionality of the SIM 868 and send the location in JSON format to a MQTT server.
All the code compile, connect and function as expected, but seems to just stop after data has been send to the server 6 times. I have attached the sketch as well as a serial sniff between the modem and CPU, and the serial console output. There is no obvious reason for the CPU to freeze up. When it freeze I need to fiscally reset the CPU as well as plugging the USB out and re inserting the connection.
Any ideas how i can further trouble shoot would be appreciated.
Fona/MQTT failure
- anpretorius
Fona/MQTT failure
- Sim868_28-11-2021.zip
- complete program
- (4.07 KiB) Downloaded 20 times
- Message on serial console
- Serial console.JPG (22.43 KiB) Viewed 747 times
- Serial Sniff between modem and CPU
- snif.PNG (9.07 KiB) Viewed 747 times
- anpretorius
Re: Fona/MQTT failure
Hi All
Maybe this can help somebody in the future.
the fault seems to have been in the JSON lib. I have now created my own JSON string and and taken the lib out of the sketch.
So far so good, everything seems to have stabilized.
Andre
Andre
