I have finally built the RGB LCD Shield. Linked below.
https://learn.adafruit.com/rgb-lcd-shield
I cant find the power cable for it in the package I received, I don't know which one to get.
What power cable/supply do I need to get to get it powered?
Thank you ladies and gents!
RGB LCD Shield
Re: RGB LCD Shield
There is no power cord for the shield. It is intended to be plugged into an Arduino and gets its power directly from the Arduino.
https://learn.adafruit.com/rgb-lcd-shie ... lcd-shield
If you want to run it detached from the Arduino, you will need to connect 4 jumper wires from the Arduino to the shield. These are not supplied in the kit.
https://learn.adafruit.com/rgb-lcd-shie ... -307081-16
