CIRCUITPY DRIVE NOT CREATED
roncase
Post by roncase »
Thursday, December 2, 2021
CLUE and FEATHER Mo EXPRESS no CIRCUITPY Drive
The CIRCUITPY drive is not created when starting either board.
Using WINDOWS10. Testing on two WINDOWS10 and a Chrome tablet.
The CLUE display indicates "Filesystem not found"
All other sensor data is working fine.
The problem started on the FeatherMo about November 11.
Received the CLUE December 1 and it never could create CIRCUITYP Drive.
Double click the CLUE Reset and FEATHERBOOT (G:) drive is created.
The capability to create a new drive is working.
Doesn't seem to be a problem of the board but the method being used at startup isn't working.
dastels
Re: CIRCUITPY DRIVE NOT CREATED
Post by dastels »
Have you installed CircuitPython on the boards? The CLUE comes loaded with a C++ demo as I recall. Get the CircuitPython UF2 files for the boards from https://circuitpython.org/downloads and copy each onto the respective BOOT drive.
For more see https://learn.adafruit.com/welcome-to-circuitpython.
roncase
Post by roncase »
Hi Dastels:
Neither my (new CLUE or FEATHER M4) activate anything when they are plugged in.
The CLUE displays "Filesystem not found" (and displays the local sensor data)
How do I access the files if I can't open any directory (or anything) with "Filesystem no found".
Double click the Reset and FEATHERBOOT (G:) is created
Therefore: The capability to create a new drive is working.
This is not a problem of the board but the method being used at startup isn't working.
The same problem exist of both boards.
Same results on two different Windows10 computers.
I did notice that Window10, November 2021 had an update "features for productivity and security".
This was when the problem began (but probably unrelated?)
Thanks for any suggestions.
dastels
Post by dastels »
I'll repeat myself:
Return to “CLUE Board”
