Connecting amp to a CLUE + using timer
hohx15
Post by hohx15 »
Hello experts,
I am trying to build a timer with speaker based on CLUE.
My questions are :
(1) (BOARD CONFIGURATION)
How do I connect Adafruit Mono 2.5W Class D Audio Amplifier - PAM8302 on the breadboard?
Just one output pin - amp - GND like horizontally on each end of the amp?
(2) (CODE)
What do I need to do in Arduino IDE ?
What kind of code or header files do I need to control the speaker?
(3) (PIN)
I have already soldered pin 2 as output. Does it matter which pin I use?
(4) TIMER
Here is my code for my timer, and why does it not play music on D46 built in speaker after time is up?
volatile uint16_t milliseconds = 8000;
void timercallback() {
timecounter = milliseconds/1000;
//analogWrite(LED_BUILTIN, milliseconds); // pulse the LED
if (milliseconds == 0) {
delay(1000);
playMusic();
} else {
milliseconds--;
pinMode(46, OUTPUT);
Serial.begin(115200);
void loop{
timercallback();
int speed=50; //higher value, slower notes
bool playMusic(){
for (int thisNote = 0; melody[thisNote]!=-1; thisNote++) {
int noteDuration = speed*noteDurations[thisNote];
tone(46, melody[thisNote],noteDuration*.95);
Serial.println(melody[thisNote]);
delay(noteDuration);
noTone(46);
return true;
Return to “CLUE Board”
