Network Connected RGB Matrix Clock
For RTC breakouts, etc., use the Other Products from Adafruit forum
ishankum
Re: Network Connected RGB Matrix Clock
Post by ishankum »
# Metro Matrix Clock
# Runs on Airlift Metro M4 with 64x32 RGB Matrix display & shield
import time
import board
import displayio
import terminalio
from adafruit_display_text.label import Label
from adafruit_bitmap_font import bitmap_font
from adafruit_matrixportal.network import Network
from adafruit_matrixportal.matrix import Matrix
BLINK = True
DEBUG = False
# Get wifi details and more from a secrets.py file
try:
    from secrets import secrets
except ImportError:
    print("WiFi secrets are kept in secrets.py, please add them there!")
    raise
print("    Metro Minimal Clock")
print("Time will be set for {}".format(secrets["timezone"]))
# --- Display setup ---
matrix = Matrix()
display = matrix.display
network = Network(status_neopixel=board.NEOPIXEL, debug=False)
# --- Drawing setup ---
group = displayio.Group()  # Create a Group
bitmap = displayio.Bitmap(64, 32, 2)  # Create a bitmap object,width, height, bit depth
color = displayio.Palette(4)  # Create a color palette
color[0] = 0x000000  # black background
color[1] = 0xFF0000  # red
color[2] = 0xCC4000  # amber
color[3] = 0x85FF00  # greenish
# Create a TileGrid using the Bitmap and Palette
tile_grid = displayio.TileGrid(bitmap, pixel_shader=color)
group.append(tile_grid)  # Add the TileGrid to the Group
display.show(group)
if not DEBUG:
    font = bitmap_font.load_font("/IBMPlexMono-Medium-24_jep.bdf")
else:
    font = terminalio.FONT
clock_label = Label(font)
def update_time(*, hours=None, minutes=None, show_colon=False):
    now = time.localtime()  # Get the time values we need
    if hours is None:
        hours = now[3]
    if hours >= 18 or hours < 6:  # evening hours to morning
        clock_label.color = color[1]
    else:
        clock_label.color = color[3]  # daylight hours
    if hours > 12:  # Handle times later than 12:59
        hours -= 12
    elif not hours:  # Handle times between 0:00 and 0:59
        hours = 12
    if minutes is None:
        minutes = now[4]
    if BLINK:
        colon = ":" if show_colon or now[5] % 2 else " "
    else:
        colon = ":"
    clock_label.text = "{hours}{colon}{minutes:02d}".format(
        hours=hours, minutes=minutes, colon=colon
    bbx, bby, bbwidth, bbh = clock_label.bounding_box
    # Center the label
    clock_label.x = round(display.width / 2 - bbwidth / 2)
    clock_label.y = display.height // 2
    if DEBUG:
        print("Label bounding box: {},{},{},{}".format(bbx, bby, bbwidth, bbh))
        print("Label x: {} y: {}".format(clock_label.x, clock_label.y))
last_check = None
update_time(show_colon=True)  # Display whatever time is on the board
group.append(clock_label)  # add the clock label to the group
while True:
    if last_check is None or time.monotonic() > last_check + 3600:
        try:
            update_time(
                show_colon=True
            )  # Make sure a colon is displayed while updating
            network.get_local_time()  # Synchronize Board's clock to Internet
            last_check = time.monotonic()
        except RuntimeError as e:
            print("Some error occured, retrying! -", e)
    update_time()
    time.sleep(1)
Reason: Add code tags
ishankum
Post by ishankum »
hope that was okay. If not you can find it here "https://learn.adafruit.com/network-conn ... trix-clock" ( on adafruit)
dastels
Post by dastels »
OK, it's the straight from the guide code. That should be fine then.
dastels
Post by dastels »
Near 6he start of the file there's a line: DEBUG = False. Change that to DEBUG = True, rerun it and tell me what gets output in the REPL.
ishankum
Post by ishankum »
same as before
ishankum
Post by ishankum »
copied entire code to repl and got this if it's any use
File "<stdin>", line 10, in <module>
File "adafruit_matrixportal/network.py", line 31, in <module>
File "adafruit_portalbase/network.py", line 28, in <module>
File "/lib/adafruit_io/__init__.py", line 21, in <module>
File "/lib/adafruit_io/client.py", line 24, in <module>
ImportError: no module named 'platform'
dastels
Post by dastels »
You generally can't just copy it to the REPL. Put it in CIRCUITPY/code.py and have the REPL open when it runs.
ishankum
Post by ishankum »
by that I get the same result as before
dastels
Post by dastels »
Well, the board and CircuitPython are running.
Have you tried some of the simpler examples? Maybe https://learn.adafruit.com/pixel-art-matrix-display since it doesn't use WiFi.
There should be output from those prints (which show up in the REPL) right after the secrets file is loaded.
You've confirmed that the clock code is, indeed, contained in CIRCUITPY/code.py?
ishankum
Post by ishankum »
will try a simpler code today can confirm clock code is correct have re checked and saved again
ishankum
Post by ishankum »
It works guess my .bmp file is not the best. but i do get something on the matrix which is good.
dastels
Post by dastels »
OK, so things appear to work. It comes back to whether you have the correct code in code.py.
ishankum
Post by ishankum »
code.py can't go wrong as its just copy and paste from the adafruit web page copy link is provided. same as I did with the simpler display code. did it over several times. working with mu and circuit python makes that part easy but I don't have any coding skills
dastels
Post by dastels »
This can be a problem with Mu. Verify that it is saving the code to CIRCUITPY/.
ishankum
Post by ishankum »
I am using a matrix portal m4 instead of the Airlift Metro M4 and Shield as the pdf doc says you can. Could this be the issue?
Return to “Clock Kits (discontinued)”
