Network Connected RGB Matrix Clock
- ishankum
Re: Network Connected RGB Matrix Clock
also did by drag and drop between my pc and the matrix portal so tried that also then the correct file goes in
- ishankum
confirm mu is saving file correctly
- dastels
- ishankum
finally got some output from mu serial
"Auto-reload is on. Simply save files over USB to run them or enter REPL to disable.
Adafruit CircuitPython 7.0.0 on 2021-09-20; Adafruit Matrix Portal M4 with samd51j19
soft reboot
code.py output:
Metro Minimal Clock
File "code.py", line 23, in <module>
KeyError: timezone
Code done running.
soft reboot
code.py output:
Metro Minimal Clock
KeyError: timezone
Code done running.
- dastels
OK, that's a code (or configuration) error. Sounds like a bad map/dictionary key.
- ishankum
working now thank you
