I am trying the FONA 3G module with the circuit exactly as shown in the Adafruit documentation and the Adafruit test program with a Ting SIM CARD. When I send 'G' command to start GPRS, it returns with Network Opened, however, when I send 'w' and try to read a website (I tried using the example website provided by Adafruit) the module just returns with error. This happens in every case. I have attached pictures of Serial Monitor and Circuit below.
**The phone and SMS features on the Module work fine, it is just the internet that is not working.
FONA 3G Module not reading or writing to website
- kiratmokha
- MicrosoftTeams-image.png (18.31 KiB) Viewed 865 times
- rskup
Re: FONA 3G Module not reading or writing to website
Just tossing this out there...did you set your APN according to what your carrier says using the AT+CGDCONT command?
- kiratmokha
Thanks for the suggestion, I just checked on the Ting website and the APN is listed as 'wholesale'. I had not added this to the FONA Test code. I am going to add it in and try again.
- kiratmokha
Hello rskup, I set the APN from the Ting website in the FONA test code from Adafruit and I am still getting the same errors unfortunately. If you have anymore advise please let me know, thanks!rskup wrote:Just tossing this out there...did you set your APN according to what your carrier says using the AT+CGDCONT command?
- rskup
Interestingly, I also now cannot download web pages with my FONA 3G. I got out my old notes on how to do it manually entering the AT commands (as opposed to using the FONA Test sketch), but it won't work now. I wonder if it may have something to do with 3G shutting down??
Anyways, I'm gonna try some more things, then dig out a Waveshare 4G board that I have (SimCom 7600 chip) to confirm I'm using the right AT commands, and will update the post.
- kiratmokha
Sounds good, thanks! Adafruit has not been replying about this issue at all. I am on a huge time crush with my senior design group on this project where we are supposed to build a GPS tracker which sends coordinates to a database using cellular. So, if you have any other suggestions of GPS/3G/4G modules I'd appreciate that.
- rskup
Well, not sure what happened, turned FONA off/on and then things worked better...but not perfect unfortunately.
I seem to be able to connect to wifitest.adafruit.com, and even get back an "OK".
However, I can't seem to get past that point....ug. Will try more stuff later.
Just a couple things...I saw on TING there are two APNs depending on your sim card...maybe double-check you're using the right APN for your sim.
And double-check the FONA 3G took your APN entry by entering the AT command:
AT+CGDCONT?
You should see your APN in the line that's returned.
One more thing to check ... since you're using the FONA Test sketch, I seem to recall there's a line in there near the beginning you have to "un-comment" if you're using the FONA 3G ... did you do that? Otherwise the sketch treats your FONA 3G like it's a FONA 800/808.
Ok, hopefully better news tomorrow.
AT+CGDCONT?
- rskup
Yep, me again, look at this post I just found, could be helpful:
viewtopic.php?f=54&t=175691&p=856048&hilit=http#p856048
- kiratmokha
Thanks for that update. I have tried both APN and used the ‘start GPRS’ function from the test sketch and every time I run it, it opens the network successfully, however, when I try to read or write, I am unable to. I just get errors. There’s also a screenshot of this in the post.
I’ll try the AT command you said tomorrow and also see if I can just push AT commands to the module directly instead of going through the test sketch.
If possible, would you be willing to share your schematic and code please?
- kiratmokha
Looks great! Thank you for that. I will try I tomorrow and update the results in this post.rskup wrote:Yep, me again, look at this post I just found, could be helpful:
- rskup
Well, at least I'm getting html back from Adafruit, it's just that it's the html for a "400 Bad Request" webpage.
Need to do some more research, but here's what I'm typing manually (I'm using X-CTU, I know most folks use PuTTY):
AT+CHTTPSSTART
AT+CHTTPSOPSE="wifitest.adafruit.com",80,1
AT+CHTTPSSEND=38
after the above you'll get a ">", then:
GET /testwifi/index.html HTTP/1.1
now it gets a little tricky sending ctrl stuff: ctrl-M, ctrl-J, ctrl-M, ctrl-J, alt-026
and after a moment I actually get back: CHTTPS: RECV EVENT
yeah!!!
So then enter:
AT+CHTTPSRECV?
and you get back a number, in my case, 327
then you enter:
AT+CHTTPSRECV=327
then the web page html will print out, but as I said, it's for a "400 Bad Request" webpage, sigh.
To exit out of http mode, enter:
AT+CHTTPSSTOP
Anyways, that's as close as I'm getting for now, gotta do some other stuff here, then I'll dig and test, curious now how to do this again.
AT+CHTTPSSTART
AT+CHTTPSSEND=38
yeah!!!
So then enter:
AT+CHTTPSRECV?
then you enter:
AT+CHTTPSRECV=327
AT+CHTTPSSTOP
- rskup
OMG, got it working, and got back the "This is a test of Adafruit WiFi! If you can read this, its working :)" string!!
Ok, here the list of AT commands I manually typed in (btw, I switched to using PuTTY this time):
AT+CHTTPSSTART
AT+CHTTPSSEND=69
(now you'll get the ">" cursor)
type ctrl-M, ctrl-J
Host: wifitest.adafruit.com:80
type ctrl-M, ctrl-J, ctrl-M, ctrl-J
(after a moment, you should get an OK and a +CHTTPS: RECV EVENT)
AT+CHTTPSRECV?
(I got back 314 here)
AT+CHTTPSRECV=314
After the above you'll get some header info and the confirmation text from Adafruit!
Again, to get out of this http mode, enter:
AT+CHTTPSSTOP
Hope it works for you!
edit - btw, the 69 is the number of characters after the ">", plus the 6 ctrl characters
AT+CHTTPSSTART
AT+CHTTPSSEND=69
type ctrl-M, ctrl-J
AT+CHTTPSRECV?
AT+CHTTPSRECV=314
AT+CHTTPSSTOP
- rskup
me again, took a pic of the PuTTY screen, it doesn't show the ctrl characters of course, but you can see everything else.
- putty.png (31.59 KiB) Viewed 843 times
- kiratmokha
Thank you so much for the update! I will give that a shot. Just one more question, what SIM card provider were you using with your FONA 3G?
- kiratmokha
Looks great! Just another question, what SIM card provider are you using with your FONA 3G?rskup wrote:me again, took a pic of the PuTTY screen, it doesn't show the ctrl characters of course, but you can see everything else.
