Adafruit dt-9205b+ won't measure volts or amps
- brentschmidt
Fuse checks good with another meter. Swapping leads didn't help either. It will, however, measure resistance. Is it salvagable?
- rpiloverbd
Re: Adafruit dt-9205b+ won't measure volts or amps
If there is no luck after selecting the correct mode, then probably you got a problematic meter. Hope team adafruit will come forward to give you a good solution.
