Hello! I am hoping to operate one of micro:bit’s Smart Cutebots with an Adafruit CLUE. I have found an old .mpy file (titled “jisforjt_cutebot_clue.mpy”) online that allegedly would let the two communicate through circuit python along with some code examples that all seem straightforward, but I get an .mpy error in the Mu Editor serial, I assume, because the library files are from circuitpython v5.3.1 and my CLUE is running v7+.
So I’m wondering if there are either 1) legacy installer versions of circuit python I could install to match the v5.3.1 .mpy files I have, or, 2) if there is a simple way to update any .mpy file to run with newer versions of circuit python in this specific instance? Or, maybe, there are some newer library files for this task that I’m just overlooking somewhere.
Old .mpy files for Cutebot and CLUE
- neradoc
Re: Old .mpy files for Cutebot and CLUE
Seemingly the python version of the file is here, you can just use that. The code might still need updating to CP7, which you can get help with here too.
https://github.com/jisforjt/CircuitPython_CLUE_Cutebot
Alternatively some older versions of CP are available:
https://adafruit-circuit-python.s3.amaz ... ess/en_US/
- elysobad
I was able to get it running with one of the older cp versions - thank you!
