Fona 800 + Pi Zero solar power
Adafruit cellular platform - SMS and IoT over celluar
sarahdal
Post by sarahdal »
I've seen several different answers to this, I have a pizero logging and sending the data through the fona, and ideally would like it all powered through solar and a lipo.
I'm using the bq24074 charger to charge the main battery and power the pi through solar. Can I just split the load output to power both the pi and the Fona's lipo charging circuit? I have a second battery plugged in to the fona.
sarahdal
Re: Fona 800 + Pi Zero solar power
Post by sarahdal »
For the second time I think I've managed to answer my own question before anyone can reply!
I think I can split the load output from the lipo solar charger bq24074 and run one to the pi, and one to the 5V pin on the FONA? That's the 5V nearest the existing usb. And the ground to ground.
adafruit_support_mike
You'd want to connect the LiPo to the battery connector on the FONA instead of the 5V pin. Other than that, you should be good.
fgnievinski
Post by fgnievinski »
Not really.. the BQ24074 doesn't produce 5V output, so the FONA's onboard LiPo charger won't get enough supply voltage.
Connect the LiPo to the Solar Charger's BAT connector, then connect the charger's LOAD output to the FONA's BAT pin and the microcontroller's power pin.
sarahdal
Post by sarahdal »
Do I still need the seperate LiPo for the FONA card in this arrangement?
fgnievinski
adafruit_support_mike wrote:(... ) Connect the LiPo to the Solar Charger's BAT connector, then connect the charger's LOAD output to the FONA's BAT pin and the microcontroller's power pin.
maybe option 1 here?
viewtopic.php?f=62&t=184595#p896435
thank you for the clarification.
-FGN.
sarahdal wrote:Do I still need the seperate LiPo for the FONA card in this arrangement?
No. Connecting the charger's LOAD output to the FONA's JST-PH2 jack is a good enough connection.
sarahdal
Post by sarahdal »
Excellent, thank you!
Return to “FONA”
