JST PH 2-Pin Cable - ID: 261
Hand tools, soldering irons, scopes, multimeters. Talk about em HERE!
simejis
Post by simejis »
***** QD44E8C *****
can you please advise on the used cable in the assembly P/N 261?
https://www.adafruit.com/product/261#technical-details
One of our customers would need more detailed information about the used wires, like:
The best would be the part number and the manufacturer of the wires.
If it's not possible, i need to have the conductor size and type, the insulation material, as well as the max voltage and the max temperature, please
Would you be able to provide these details?
Thank you very much
Best regards
Adnan
adafruit_support_mike
Re: JST PH 2-Pin Cable - ID: 261
We don't have specific details, but the wire is 22 gauge 19/34 stranded, tinned, with PVC insulation.
The usual temperature range for such wire is -40C to 105C.
If your customer needs fully-spec'd cables, they'll probably need to work with a cable fabrication company where they can specify their own BOM.
Return to “Tools Tools Tools”
