Killed new multimeter?
Hand tools, soldering irons, scopes, multimeters. Talk about em HERE!
inforoo
Post by inforoo »
I just bought this multimeter: https://www.adafruit.com/product/2034
It stopped working. I replaced fuse the and battery but no dice. It's always showing out of range.
Any ideas? Is it possible to exchange it?
sj_remington
Re: Killed new multimeter?
Post by sj_remington »
What were you doing with the multimeter when it "stopped working"?
inforoo
Post by inforoo »
Testing circuit continuity on a protoboard I had soldered.
Franklin97355
Post by Franklin97355 »
What are you connecting the leads in and what setting of the dials?
inforoo
Post by inforoo »
This setting (will post pics of the board on a moment):
Digital_Multimeter_-_Model_9205B____ID_2034____17_50___Adafruit_Industries__Unique___fun_DIY_electronics_and_kits.png
Digital_Multimeter_-_Model_9205B____ID_2034____17_50___Adafruit_Industries__Unique___fun_DIY_electronics_and_kits.png (884.11 KiB) Viewed 1274 times
inforoo
Post by inforoo »
Pics of the board below. Notably it was not powered nor was the bolt IOT board connected when the meter began to fail.
Franklin97355
Do you know what caused the burn?
inforoo
Post by inforoo »
franklin97355 wrote:Do you know what caused the burn?
Yes, my poor soldering skills. That was a couple days before I went to check all those solders with the multimeter though.
freddyboomboom
Post by freddyboomboom »
The continuity setting is actually for a rough check of the "breakover voltage" for diodes.
It's better to use the "ohms" setting if you are checking that your soldering/wiring is correct.
Lots of people like getting the "beep", but it can give you a false sense of security if you're really concerned with a low resistance connection.
Return to “Tools Tools Tools”
