Hi, I have M4 hallowing and am helping a student with a project. They want to use the https://learn.adafruit.com/hallowing-sp ... d/software hallowing spirit board UF2 but when we load it, it just ejects my board and when the board reappears it is still in HALLOM4BOOT mode. Of course I have tried switching it back and forth with the newest Circuitpy. Does this project only work on the MOs by chance? Tbh it does the same with the SpookyEye UF2...and when I download the diagnostics UF2 it just ejects and never reappears at all....I can get the blink code to run in Arduino but the All Seeing Skull code seems to be depreciated for the current libraries...?
Thanks for your help.
Hybrid Lab
Is Sprit Board only for Hallowing MO and not M4?
- HybridLabCCA
- dastels
Re: Is Sprit Board only for Hallowing MO and not M4?
I'm not surprised that the supplied UF2 doesn't work. The "M0" hallowing uses a SAMD21 MCU, while the "M4" uses a SAMD51 MSCU. I suspect it will work if you build it from source with the board set to Hallowing M4.
