Circuit Playground Express not connecting
This is a special forum devoted to educators using Adafruit and Arduino products for teaching.
CBurks
Post by CBurks »
have 2 Adafruit Circuit Playground Express units. One connects fine to the Makecode website. The second one won't connect to makecode but it will connect to Code.org Unit 6 circuit playground lessons. What do I need to do to get it to work on the Makecode website?
Also, the Adafruit NeoPixel LED Dots Strand - 20 LEDs at 2" Pitch that I bought for a student to do the Glue Stick Light Tunnel doesn't look like the pictures are showing on connection. I have upload 2 pictures for comparison. Any help is appreciated.
Picture from the website
NeoPixel Image.JPG (112.71 KiB) Viewed 1836 times
Picture of what I have
tepalia02
Re: Circuit Playground Express not connecting
Post by tepalia02 »
Hi, did someone contact you regarding this issue?
Franklin97355
Post by Franklin97355 »
@CBurks The picture you posted is using a plug that you can buy here or you could cut the output end off and connect it to the CPX for a plug-in connection. I'm not sure it will work with one program and not the other but someone might know. Can you post a picture of the input side of the strip with the first pixel showing and the code that does not work?
Return to “For Educators”
