Circuit Playground Classics---dying in droves
This is a special forum devoted to educators using Adafruit and Arduino products for teaching.
shop4mondon
Post by shop4mondon »
Howdy
We have several Circuit Playground Classics. They have been working great until last week. They have all quit accepting uploads. One at a time they will quit accepting even simple sketches like "Blink". We have tried all of the suggestions about reseting...double clicking the reset button, etc...
We've tried MacOS and Windows...we get the same error
Here is the message we get:
Arduino: 1.8.19 (Windows 10), Board: "Adafruit Circuit Playground"
Sketch uses 3868 bytes (13%) of program storage space. Maximum is 28672 bytes.
Global variables use 149 bytes of dynamic memory.
Forcing reset using 1200bps open/close on port COM3
PORTS {COM3, } / {} => {}
PORTS {} / {COM3, } => {COM3, }
Found upload port: COM3
C:\Users\shop4\Desktop\arduino-1.8.19-windows\arduino-1.8.19\hardware\tools\avr/bin/avrdude -CC:\Users\shop4\Desktop\arduino-1.8.19-windows\arduino-1.8.19\hardware\tools\avr/etc/avrdude.conf -v -patmega32u4 -cavr109 -PCOM3 -b57600 -D -Uflash:w:C:\Users\shop4\AppData\Local\Temp\arduino_build_799171/Blink.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\shop4\Desktop\arduino-1.8.19-windows\arduino-1.8.19\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : avr109
         Overriding Baud Rate          : 57600
         AVR Part                      : ATmega32U4
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  9000  9000 0x00 0x00
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : butterfly
         Description     : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding
Problem uploading to board.  See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
Last edited by adafruit_support_carter on Tue May 10, 2022 12:30 pm, edited 1 time in total.
Reason: added [code] tags
Re: Circuit Playground Classics---dying in droves
What has changed from last week when they were working to now?
shop4mondon
We have not changed anything. Students just started coming to me with errors. I would give them another device and they would come back later with the same error. I Tested a functioning device myself. I uploaded example sketches. It worked for a while. After several uploads, it quit working as well.
shop4mondon
This is part of the error message
"Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding"
I don't understand the IDE well enough to know if this is the problem
freddyboomboom
Post by freddyboomboom »
When I do a web search for that, the issues seem to stem from the wrong board being selected in the Arduino IDE.
Ensure the students are selecting the Circuit Playground Classic.
Also, if using Linux, ensure that modemmanager is uninstalled.
After the students are given the Circuit Playgrounds, what do they do with them? Are they being supervised?
shop4mondon
THANX for trying to help...
Like I said, we were having great success with these gadgets until just recently.
Students started getting errors, so I tested one myself.
I put example sketches on one...after several uploads, I got the same error.
ANY technical suggestions would be greatly appreciated
This testing is being done with a new Circuit Playground that has not been used by students?
You are simply uploading the same example sketch over and over, and it eventually fails to upload?
shop4mondon
I used a device that had not been previously used by anyone.
I uploaded a variety of example sketches.
And at some point the example sketch does not upload? No other changes. Just uploading the same sketch over and over and it suddenly fails to upload?
shop4mondon
We will attempt an upload....
It will say it's uploading for a long time, then give us a simple error stating it failed.
I used the verbose feature and printed out the error. I posted it previously, but here it is again.
Using Port : COM3
PAGEL : PD7
BS2 : PA0
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Problem uploading to board. See https://support.arduino.cc/hc/en-us/sec ... 0003198300 for suggestions.
What was done just prior to that failed upload? A successful upload of the exact same sketch? Something else?
shop4mondon
We cannot determine what causes it....
Sometimes we are uploading an original sketch, sometimes it's an example, sometimes it's the "Blink" sketch!
But at some point it goes from working to not working. In the example shown above that is failing to upload a Blink sketch, is it known what the last successful upload to that board was?
shop4mondon
It has varied....sometimes it's an original sketch...other times it's an example
We're pretty good at basic trouble shooting, but we're stumped
Return to “For Educators”
