ESP32 v2 pico py
- adafruit2
Re: ESP32 v2 pico py
it works just fine, the scan found both displays. you probably have to go through the code and make sure you're using Wire1 not Wire in the library - check the library documentation for how to do that
- seskindell
I figured that ...
Another problem NONE of the bluetooth functions work.
Does not connect to any devices ... it all works with the adafruit esp32.
- adafruit2
antenna is a lot smaller, make sure its near your devices
- seskindell
It's right on top of the phone.
All functions work with the tinypico, sparkfun thing esp32 plus, and Adafruit ESP32 feather ttgo t1.
No functions work with the ble library and the Adfruit py pico.
- adafruit2
sesk - ok email support@adafruit for a refund, and you can use a different board instead of the qtpy like the feather you say works perfectly for you.
