Adafruit Bluefruit MO and setting it up for a midi device
Re: Adafruit Bluefruit MO and setting it up for a midi devic
The tutorials have links to all the code you’ll need.
- kingmichaelcoy222
The midi example works for the feather m0 however, it sends midi notes that are auto triggering by itself. Im wondering is there a ble library that will actually work for the feather m0.
- kingmichaelcoy222
The BLe Untztrument compiled successfully, now, I just have to make sure the right pins are connected.
- freddyboomboom
I don't know about any of your questions, but it looks to me like you're selecting the wrong board in Arduino:
So that's probably why you're getting:Arduino: 1.8.19 (Mac OS X), Board: "Adafruit Feather M0 (SAMD21), Small (-Os) (standard), Arduino, Off"
/Users/kingmichaelcoy/Documents/Arduino/libraries/USB_Host_Shield_Library_2.0/avrpins.h:1360:2: error: #error "Please define board in avrpins.h"
1360 | #error "Please define board in avrpins.h"
- kingmichaelcoy222
Here’s a better question. It is said on the feather m0 product page that 8,7,4 are the pins needed to connect to blue fruit le. However when I look on the board I cannot find those numbers. Can you help me specify?
- freddyboomboom
You said earlier that you are using the Feather M0 Bluefruit LE, product ID 2995.
The learn guide for that board says they are internally connected to the BLE module.
https://learn.adafruit.com/adafruit-fea ... le/pinouts
Again, in Arduino, make sure you are specifying the Feather M0 Bluefruit LE. If you select one of the other Feather M0 boards IT WILL NOT WORK.
- kingmichaelcoy222
Am i able to use the feather m0 to trigger midi with just a breadboard and buttons. Or do I have to use that with a uno to utilize the button triggering?
