Hi guys I'm King. This is my very first post. I'm designing a drum machine right now well what I want to ask is regarding the Bluetooth Le page where they show how to make a midi device from breadboard
Ex.https://images.app.goo.gl/K57oowRp8kbhpdK87
So im trying to test this project on a adafruit feather Mo. I have near identical connections to my breadboard other than the colors of the wires. When I try to upload the code of the 47 effect midi library it fails to upload. That is not my question. My question is can I do this project with the feather Mo and also why is the suggested midi library not available?
I got it but I don't think it's the correct version.
Adafruit Bluefruit MO and setting it up for a midi device
- kingmichaelcoy222
Re: Adafruit Bluefruit MO and setting it up for a midi devic
The image you linked is from this tutorial:
https://learn.adafruit.com/web-ble-midi ... controller
and there are several other BLE MIDI projects:
https://learn.adafruit.com/search?q=ble%2520midi
- kingmichaelcoy222
below is my problem
I am trying to upload the Ble midi library to my Feather M0, and I got this error message.
Arduino: 1.8.19 (Mac OS X), Board: "Adafruit Feather M0 (SAMD21), Small (-Os) (standard), Arduino, Off"
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/kingmichaelcoy/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/kingmichaelcoy/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/kingmichaelcoy/Documents/Arduino/libraries -fqbn=adafruit:samd:adafruit_feather_m0:opt=small,usbstack=arduino,debug=off -vid-pid=239A_800B -ide-version=10819 -build-path /var/folders/2q/g1v4bwfs2cg3v7cqwb13y6c80000gp/T/arduino_build_945189 -warnings=all -build-cache /var/folders/2q/g1v4bwfs2cg3v7cqwb13y6c80000gp/T/arduino_cache_657395 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.bossac.path=/Users/kingmichaelcoy/Library/Arduino15/packages/arduino/tools/bossac/1.7.0-arduino3 -prefs=runtime.tools.bossac-1.8.0-48-gb176eee.path=/Users/kingmichaelcoy/Library/Arduino15/packages/adafruit/tools/bossac/1.8.0-48-gb176eee -prefs=runtime.tools.CMSIS.path=/Users/kingmichaelcoy/Library/Arduino15/packages/adafruit/tools/CMSIS/5.4.0 -prefs=runtime.tools.CMSIS-5.4.0.path=/Users/kingmichaelcoy/Library/Arduino15/packages/adafruit/tools/CMSIS/5.4.0 -prefs=runtime.tools.CMSIS-Atmel.path=/Users/kingmichaelcoy/Library/Arduino15/packages/adafruit/tools/CMSIS-Atmel/1.2.2 -prefs=runtime.tools.CMSIS-Atmel-1.2.2.path=/Users/kingmichaelcoy/Library/Arduino15/packages/adafruit/tools/CMSIS-Atmel/1.2.2 -prefs=runtime.tools.arduinoOTA.path=/Users/kingmichaelcoy/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=/Users/kingmichaelcoy/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -prefs=runtime.tools.bossac-1.7.0-arduino3.path=/Users/kingmichaelcoy/Library/Arduino15/packages/arduino/tools/bossac/1.7.0-arduino3 -prefs=runtime.tools.arm-none-eabi-gcc.path=/Users/kingmichaelcoy/Library/Arduino15/packages/adafruit/tools/arm-none-eabi-gcc/9-2019q4 -prefs=runtime.tools.arm-none-eabi-gcc-9-2019q4.path=/Users/kingmichaelcoy/Library/Arduino15/packages/adafruit/tools/arm-none-eabi-gcc/9-2019q4 -prefs=runtime.tools.openocd.path=/Users/kingmichaelcoy/Library/Arduino15/packages/arduino/tools/openocd/0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=/Users/kingmichaelcoy/Library/Arduino15/packages/arduino/tools/openocd/0.10.0-arduino7 -verbose /Users/kingmichaelcoy/Documents/Arduino/SIMMIDI_M0/SIMMIDI_M0.ino
/Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/kingmichaelcoy/Library/Arduino15/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/kingmichaelcoy/Library/Arduino15/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/kingmichaelcoy/Documents/Arduino/libraries -fqbn=adafruit:samd:adafruit_feather_m0:opt=small,usbstack=arduino,debug=off -vid-pid=239A_800B -ide-version=10819 -build-path /var/folders/2q/g1v4bwfs2cg3v7cqwb13y6c80000gp/T/arduino_build_945189 -warnings=all -build-cache /var/folders/2q/g1v4bwfs2cg3v7cqwb13y6c80000gp/T/arduino_cache_657395 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.bossac.path=/Users/kingmichaelcoy/Library/Arduino15/packages/arduino/tools/bossac/1.7.0-arduino3 -prefs=runtime.tools.bossac-1.8.0-48-gb176eee.path=/Users/kingmichaelcoy/Library/Arduino15/packages/adafruit/tools/bossac/1.8.0-48-gb176eee -prefs=runtime.tools.CMSIS.path=/Users/kingmichaelcoy/Library/Arduino15/packages/adafruit/tools/CMSIS/5.4.0 -prefs=runtime.tools.CMSIS-5.4.0.path=/Users/kingmichaelcoy/Library/Arduino15/packages/adafruit/tools/CMSIS/5.4.0 -prefs=runtime.tools.CMSIS-Atmel.path=/Users/kingmichaelcoy/Library/Arduino15/packages/adafruit/tools/CMSIS-Atmel/1.2.2 -prefs=runtime.tools.CMSIS-Atmel-1.2.2.path=/Users/kingmichaelcoy/Library/Arduino15/packages/adafruit/tools/CMSIS-Atmel/1.2.2 -prefs=runtime.tools.arduinoOTA.path=/Users/kingmichaelcoy/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=/Users/kingmichaelcoy/Library/Arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -prefs=runtime.tools.bossac-1.7.0-arduino3.path=/Users/kingmichaelcoy/Library/Arduino15/packages/arduino/tools/bossac/1.7.0-arduino3 -prefs=runtime.tools.arm-none-eabi-gcc.path=/Users/kingmichaelcoy/Library/Arduino15/packages/adafruit/tools/arm-none-eabi-gcc/9-2019q4 -prefs=runtime.tools.arm-none-eabi-gcc-9-2019q4.path=/Users/kingmichaelcoy/Library/Arduino15/packages/adafruit/tools/arm-none-eabi-gcc/9-2019q4 -prefs=runtime.tools.openocd.path=/Users/kingmichaelcoy/Library/Arduino15/packages/arduino/tools/openocd/0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=/Users/kingmichaelcoy/Library/Arduino15/packages/arduino/tools/openocd/0.10.0-arduino7 -verbose /Users/kingmichaelcoy/Documents/Arduino/SIMMIDI_M0/SIMMIDI_M0.ino
Using board 'adafruit_feather_m0' from platform in folder: /Users/kingmichaelcoy/Library/Arduino15/packages/adafruit/hardware/samd/1.7.10
Using core 'arduino' from platform in folder: /Users/kingmichaelcoy/Library/Arduino15/packages/adafruit/hardware/samd/1.7.10
Detecting libraries used...
/Users/kingmichaelcoy/Library/Arduino15/packages/adafruit/tools/arm-none-eabi-gcc/9-2019q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -Werror=return-type -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions "-D__SKETCH_NAME__=\"\"\"SIMMIDI_M0.ino\"\"\"" -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_ZERO -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ADAFRUIT -D__SAMD21G18A__ -DADAFRUIT_FEATHER_M0 -DARDUINO_SAMD_ZERO -DARM_MATH_CM0PLUS -DUSB_VID=0x239A -DUSB_PID=0x800B -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Feather M0\"" -I/Users/kingmichaelcoy/Library/Arduino15/packages/adafruit/hardware/samd/1.7.10/libraries/Adafruit_TinyUSB_Arduino/src/arduino -Os -D__SAMD21G18A__ -DADAFRUIT_FEATHER_M0 -DARDUINO_SAMD_ZERO -DARM_MATH_CM0PLUS -DUSB_VID=0x239A -DUSB_PID=0x800B -DUSBCON -DUSB_CONFIG_POWER=100 "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Feather M0\"" -I/Users/kingmichaelcoy/Library/Arduino15/packages/adafruit/hardware/samd/1.7.10/libraries/Adafruit_TinyUSB_Arduino/src/arduino -I/Users/kingmichaelcoy/Library/Arduino15/packages/adafruit/tools/CMSIS/5.4.0/CMSIS/Core/Include/ -I/Users/kingmichaelcoy/Library/Arduino15/packages/adafruit/tools/CMSIS/5.4.0/CMSIS/DSP/Include/ -I/Users/kingmichaelcoy/Library/Arduino15/packages/adafruit/tools/CMSIS-Atmel/1.2.2/CMSIS/Device/ATMEL/ -I/Users/kingmichaelcoy/Library/Arduino15/packages/adafruit/hardware/samd/1.7.10/cores/arduino -I/Users/kingmichaelcoy/Library/Arduino15/packages/adafruit/hardware/samd/1.7.10/variants/feather_m0 /var/folders/2q/g1v4bwfs2cg3v7cqwb13y6c80000gp/T/arduino_build_945189/sketch/SIMMIDI_M0.ino.cpp -o /dev/null
SIMMIDI_M0:17:10: fatal error: Bluefruit.h: No such file or directoryAlternatives for Bluefruit.h: []
17 | #include <Bluefruit.h>
ResolveLibrary(Bluefruit.h)
-> candidates: [] | ^~~~~~~~~~~~~
compilation terminated.
exit status 1
exit status 1
This is the relevant line:
What BLE device are you connecting to the Feather?
The Feather M0 core doesn't contain BLE support by itself.. the chip doesn't have a radio.kingmichaelcoy222 wrote:SIMMIDI_M0:17:10: fatal error: Bluefruit.h: No such file or directoryAlternatives for Bluefruit.h: []
- kingmichaelcoy222
Its a feather weight OLED, should I disconnect it?
Could you post a link to the product page please? I don't recognize that as the name of one of our BLE boards.
- kingmichaelcoy222
So, I can't put midi on that particular one? hmm. I also have a Nrf52832 and I know that does midi, but I'm having a hard time getting my bootloader to load on that one.
- kingmichaelcoy222
so,
I can't use ble midi or bluetooth midi with
https://www.adafruit.com/product/2995
I have a featherwing oled.
https://www.adafruit.com/product/2900
https://www.adafruit.com/product/3406
I know the screen does not create any midi
but out of the nrf52832 and the feathering m0 which one is better for midi and bluetooth midi?
The Feather M0 BLE can do MIDI, I just needed to know what board you were using. The external nRF51822 modules behave differently from the nRF52 devices you program directly.
For boards with an nRF51822 module, you use the library described here:
https://learn.adafruit.com/adafruit-fea ... le-library
- kingmichaelcoy222
I’m trying to use the feather m0 with the o feather wing oled using the
Akai Mpk ble modification but with a breadboard prototype first
Here’s the link
https://github.com/brorgustav/AKAI_MPK- ... DIFICATION
It gives error after trying to compile. Just happy I know it’s possible.
Here’s the link
- kingmichaelcoy222
In file included from /Users/kingmichaelcoy/Documents/Arduino/libraries/USB_Host_Shield_Library_2.0/Usb.h:41,
from /Users/kingmichaelcoy/Documents/Arduino/libraries/USB_Host_Shield_Library_2.0/usbh_midi.h:29,
from /Users/kingmichaelcoy/Downloads/AKAI_MPK-PLAY_BLE_MODIFICATION-master/bgw_mod_mpkplay_m0bluefruit/bgw_mod_mpkplay_m0bluefruit.ino:19:
/Users/kingmichaelcoy/Documents/Arduino/libraries/USB_Host_Shield_Library_2.0/avrpins.h:1360:2: error: #error "Please define board in avrpins.h"
1360 | #error "Please define board in avrpins.h"
In file included from /Users/kingmichaelcoy/Documents/Arduino/libraries/USB_Host_Shield_Library_2.0/Usb.h:43,
/Users/kingmichaelcoy/Documents/Arduino/libraries/USB_Host_Shield_Library_2.0/usbhost.h:126:2: error: #error "No SPI entry in usbhost.h"
126 | #error "No SPI entry in usbhost.h"
exit status 1
Error compiling for board Adafruit Feather M0 (SAMD21).
this is what happens when I compile the code
exit status 1
From the function names, you’re trying to use the microcontroller as a USB host instead of a MIDI controller. That’s the other side of the connection.
- kingmichaelcoy222
so ill erase that part of the code, I just want to make a midi controller that is bluetooth
We won’t be able to do much useful debugging until you have code that’s relevant to the project. The tutorials linked from my first post above have code that’s known to work.
- kingmichaelcoy222
Well maybe I’ll start here
What library would you recommend for the feather m0 that goobers ability to have ble midi?
